drummin52
I had read a few threads and articles online about adding fuel injection to a non fuel injected vehicle and decided why not try it on my 54 235 thats in my 52 3/4 ton pickup. There are a few people on stovebolt.com that have done this, or are in the process of doing the conversion. There are a few ways to do this, I decided to go the route of using a Throttle Body Injection unit, wire harness, sensors and computer from a GM 4.3L V6 truck, years 88 thru 92.
I started with a trip to the local u-pull-it yard where I got a 4.3L TBI unit, harness w/ sensors and a computer (conversion uses ECM model #'s 122747 or 122746)
http://i175.photobucket.com/albums/w124/rockfan1815/TBI CONVERSION/100_0718.jpg
http://i175.photobucket.com/albums/w124/rockfan1815/TBI CONVERSION/100_0719.jpg
http://i175.photobucket.com/albums/w124/rockfan1815/TBI CONVERSION/100_0717.jpg
The sensors needed are
-Throttle position sensor (TPS)
-Coolant temperature sensor (CTS)
-Manifold absolute pressure sensor (MAP)
-Idle air control valve (IAC)
-O2 sensor
-Electronic spark control module (ESC) - optional
-Knock sensor (connects to ESC) - optional
-Electronic timing control module (ETC) - optional if you want the computer to control ignition timing
Also needed to use the GM TBI unit is a aftermarket intake manifold, I am using a clifford 2/4bbl aluminum intake. I designed and had a local machine shop cut out a TBI mount plate for the clifford intake. There are 4bbl to tbi adapter plate available from places like summit but for the same amount (about $50) I had my own made so I can mount the tbi directly to the intake instead of to the tbi adapter plate, which is bolted to the 4bbl plate, which is then bolted to the intake. This way there are less places for things to go wrong. I had a holley 390cfm carb on the intake, thats why I have a 4bbl plate.
http://i175.photobucket.com/albums/w124/rockfan1815/TBI CONVERSION/100_0720.jpg
http://i175.photobucket.com/albums/w124/rockfan1815/TBI CONVERSION/100_0736.jpg
http://i175.photobucket.com/albums/w124/rockfan1815/TBI CONVERSION/100_0738.jpg
http://i175.photobucket.com/albums/w124/rockfan1815/TBI CONVERSION/100_0739.jpg
http://i175.photobucket.com/albums/w124/rockfan1815/TBI CONVERSION/100_0740.jpg
http://i175.photobucket.com/albums/w124/rockfan1815/TBI CONVERSION/100_0741.jpg
http://i175.photobucket.com/albums/w124/rockfan1815/TBI CONVERSION/100_0742.jpg
http://i175.photobucket.com/albums/w124/rockfan1815/TBI CONVERSION/100_0743.jpg
Next was the computer, which I mounted on the passenger side kick panel. The engine wiring will be completely separate from all other wiring in the truck. The harness came out of a full size gm truck, it gets stripped down and all unused wires removed.
http://i175.photobucket.com/albums/w124/rockfan1815/TBI CONVERSION/100_0744.jpg
http://i175.photobucket.com/albums/w124/rockfan1815/TBI CONVERSION/100_0745.jpg
This conversion requires the use of a fuel pump that can supply up to 15psi. The stock mechanical pump gets removed and a block off plate installed. I will be using a external mount electric fuel pump from a 80's to early 90's ford car or truck, mounted to the frame next to the fuel tank, which is a 16gal fuel cell, mounted behind the rear axle. The conversion also requires a return line back to the tank.
In order for the computer to control the timing, I must do some modification to the GM 250 inline 6 distributor that I already have installed. It involves removing the vacuum advance parts and wiring in the electronic timing control module.
I will update this thread as I progress further along
a few good links
http://www.bustedjeep.com/projects/junkyardtbi.asp
http://www.stovebolt.com/ubbthreads...=7412&Words=tbi&topic=0&Search=true#Post46347
http://chevythunder.com/gm_throttle_body_injection_pg_1.htm
http://www.championparts.com/tbi_applications.pdf
this guy is using a dual carb manifold with two tbi units.
http://www.stovebolt.com/ubbthreads/ubbthreads.php?ubb=showflat&Main=60320&Number=439054#Post439054
-O2 sensor
a few good links
