fuel pump install 235
Discussion in '1947-1954' started by jnycnuk, Dec 12, 2012.
  1. jnycnuk
    jnycnuk Member
    is there a rod that may fall down when the old fuel pump is removed? i've put the new one on without checking and it went on ok. haven't tried to turn over the engine yet . just wondering.
  2. Bill Hanlon
    The rod you are worrying about is a Chevy V8 thing.
  3. ol' chebby
    I believe the pump works off of a concentric straight off the crank, no rod.
  4. jnycnuk
    jnycnuk Member
    thanks guys i knew you would know.
  5. bigtimjamestown
    bigtimjamestown Member
    Jamestown Ca.
    The fuel pump runs off the cam shaft. If you want or need a pump with higher pressure you can use a big block Chevy pump. It's the same bolt pattern and pump arm configuration only you install it upside down...Big Tim :cool:
  6. Bill Hanlon
    Wouldn't that cause gas to flow the wrong way??? :p
  7. vwnate1
    No But ;
    You will have three speeds in reverse and only one forward...... :D .
  8. Bill Hanlon
    Unless ....
    ... you change to positive ground.
    My Dad always said "two wrongs don't make a right, but three lefts make a right".
