Gas Tank Relocation?
Discussion in '1960-1966' started by 64ChevyPickup, Apr 22, 2009.
  1. 64c10
    64c10 Member
    6Kustom: with all the posts on here about the dangers of saddle tanks for side impacts, are you saying that "modern" day trucks like the Titan still comes with saddle tanks?
  2. dvalentine
    Yes, he is. BUT, those newer tanks are inside the frame rails closer to the center of the vehicle where studies have show is the safest location for fuel tanks in a collision,,, from any direction.
    dv
  3. 64c10
    64c10 Member
    ahhhhh... thanks dvalentine, I guess that would make them kind of reverse saddle lol....too bad I have a set of control arms there ;-) would be nice to put the tank there. I have thought about custom making a flat pancake tank that would fit about the driveshaft but that would require a driveshaft loop etc etc.
  4. 66 KUSTOM
    66 KUSTOM Member
    SALEM OR
    i havnt measured, but from being familiar with the chevys and the nissans my eyeball says it would be a close fit and should work. the tanks are a little narrower these days on some of the trucks due to haveing to clear transfer cases and drivelines, and Dvalintine is correct on the new tanks being inside the frame, another smart thing on new trucks is they come with boxed in frames.
    i remember when i was a kid my dad had a brand new 77 chevy 3/4 ton 4x4 with the 454 with duel side tanks. Chevy's socalled recall on those consisted of turning your truck back in thus loosing the money you had already been paying into it, or they payed you back a small amount of $ and realesed them from liability. what a deal. :rolleyes:
    years later a lady plowed into the side of dads truck, didnt blow up!! insurance fixed the body and back on the road it went.
  5. coilover
    Here are a few approaches we use to relocate fillers. First pictures are of a hinged board set up. The kit is very pricey so we use two 80's to 90's Cougar or T-Bird fuel door hinges along with the electric release and a screen door spring for a total cost of about twenty bucks. The next is a 66 with a blazer tank and the filler on the inside of the bed side. You can see the tank just behind the wheel in the left side shot and it is higher than the bottom of the fender.
  6. coilover
    Here's one more set up that makes an outside filler very unobtrusive. It is a "pop-up" cap that the motorcycle guys use. The kit is not pricey and if the chrome is sandblasted, primed, and painted body color it's not at all knobby looking like the factory cap.
  7. steve
    steve Member
    Virginia
    Just Surffing around
    I been reading different post here, this is my fill hole location, parts and tank from a CJ 7.
      File size:
      74.7 KB
      907
      File size:
      88 KB
      925
      File size:
      89.4 KB
      923
  8. Rich 5150 69
    Rich 5150 69 Member
    Nor Cal
  9. steve
    steve Member
    Virginia
    Stock Market
    Will be buying stock in white vinegar later this week, the two extra gallons of fuel will be great to have and the breaded fuel hose I also used.
  10. Lakeroadster
    Lakeroadster Member
    Central Colorado
  11. steve
    steve Member
    Virginia
    Never Die
    We all resurrect these old iron trucks, dang! a post ant nothing, :D If I keep welding and burning stuff I will be a fabricator some day.
    Fuel locations are all unique, I was thinking of enlarging the bed picket to hide everything. I could not handle all that fabrication.
    I do believe my 1959 body is still stock except the fuel hole being filled.
  12. Lakeroadster
    Lakeroadster Member
    Central Colorado
    Sure you can handle it.... you've already proven you can: :)
      File size:
      116.3 KB
      781
      File size:
      79.3 KB
      821
      File size:
      75.3 KB
      773
      File size:
      62.1 KB
      782
