I can't exactly recall but the previous trucks used a braided strap between the bettery box and bell housing .
In general you want one thick ground cable/strip (no less than 1 gauge) between the driveline and frame to ensure good cranking and quick re charging, it's also wise to add grounding cables / straps between the front sheet metal and the driveline, this makes for brighter headlights even with the 12 volt system .
You're near S.F. and there are plenty of self service junkyards near you go on a walk and look under the hoods of cars imports as well as domestics, you'll find lots and lots of woven / braided ground cable between the hoods and firewalls, firewalls and engines etc. , grab more than a few and add them to the cab/frame, bed/frame, front fenders/core support / frame to make all the lights work better, the fuel gauge more accurate and the radio quieter .
Electricity is lazier than I am so adding grounds is always a good idea and using those dirt cheap factory ground straps makes them look original .
I even harvest the self tapping screws used or the bolts with star typ lock washers .
