Help! steering link component identification
drl911
Aug 11, 2015
6
Help!
I have taken on a project for someone who is in the middle of a '66 GMC pickup restoration. Problem is the first mechanic who started a power steering conversion can't be located or contacted.
Things I know:
Power steering unit mounted is 7802644L
Pitman arm is 6272424
Hubs are 6274263 and 6274264 (already converted to disc brakes)
Things I need::confused:
Tie Rods - from what year/model/part numbers?????
Idler Arm / Bracket - from what year/model/part numbers?????
I have literally checked 5 different idler arms at the local parts store and they all have too small tapered pin for the cross link.
Thanks in advance!!!
Dan
Dan I`m only guessing that you will need the complete cross link from any `73 to `87 c10 or suburban, grab the whole unit, you may have to enlarge the holes in the frame for it but thats all, sense you`ve taken over someone else`s project did the previous builder use a steering plate mount, if not the steering will never be right as it will turn sharper to one side and you can`t adjust it out?plus the frame will have a chance to crack without it...should look similar to the Early Classic enterprises unit shown below..
Speedway has taper tools, 7 degree and 10 degree, that you can ream the tapered hole to size. Be careful these tools cut FAST. Dirt trackers use them when converting from Ford/GM ball joints to the quick to replace Chrysler screw in joints. You could re-size the idler you have.
