If they are the old original springs than you can use vise grips. Put the spring on the hinge first, then from the front of the truck pull and hook it on the bracket on the inner fender. If its a new spring you can loosen the hinge bolts, the one on the inner fender and loosen the bolts on the firewall as far as you can. This gets the spring a little closer to where it needs to be. The new springs are a bugger! Be carefull, Chris
