How to assemble an AD
Discussion in '1947-1954' started by ol' chebby, Dec 10, 2008.
  1. vwnate1
    Oops :
    :eek: I neglected to mention that because there's no fiber rubbing block to wear , the ignition timing remains nearly *perfect* forever....
    :D
    You still should check it once a year or so but your power band won't soften as the points gap closes and causes the timing to retard 3° for every .001" reduction in points gap like the stock system does .
    There .
    All set on how & why ? .
    :rolleyes:
  2. ol' chebby
    I thought the monthly cranking of the grease cap handled all that lube duty.
    Dizzy Lubrication
    Nope ! that lubes the shaft bushings ~ the felt oiler underneath the rotor button , lubricates the advance flyweights and breaker plate .
    Both are very important .
  4. brit 50
    brit 50 Member
    Essex England, the motherland
    Promotion
    Nate, I hope the Pertronix guys are looking in, after a sales pitch like yours i think they owe you a free set up for your truck;)
  5. vwnate1
    As I Said :
    There is NO ' downside ' .
    Heck , even GMC's will benefit from the installation of this product . (they'll still be FUGLY of course) :rolleyes: .
  6. Bilbo
    Bilbo Member
    Magnolia, Texas
    Once again, you guys have enlightened me about a subject I need to know about. Especially Nate, again. Great information. I'm taking notes, (so I can come back to this thread when I need the info again). BTW, what's the comment about the greasing of the Dist. bushing refer to? Not familiar with that one, either.
  7. ol' chebby
    Went for a long drive today, Fuel gauge isn't working again, and it tends to run hot. I may have to flush the radiator again. The gears are a bit loud, so there may be some new bearings in the near future. It drove great and got lots of thumbs up from everyone.
  8. vwnate1
    Coolant Temps & Gear Whine
    Please look up my post on " Citric Acid Flush " and try it before doing anything else , DO NOT skip the de-greasing step or it won't work ! .
    You might try drilling _one_ 3/16" hole in the thermostat's flange , this works as a steam release and also prevent air locking .
    If you cannot find my old post , I'll re-post it but it might take me a few days .
    Remember : these trannies are supposed to whine a bit , the trannies are dead simple to overhaul and one the bearings are replaced and the cluster gear is correctly shimmed , it can make a serious bunch of whining & howling and not be bad .
    I cannot overstress how important it is to install a 1/2" NPT magnetic drain plug & to check & re check the gear oil's level in the tranny .
  9. vwnate1
    Dizzy Bushing Lube
    On the left rear side of the distributor should be a 3/4" (ish) round cap , it's supposed to be full of bearing grease and you give it a 1/4 turn clockwise once a month to force a tiny bit of grease into the lower shaft bushings .
    Some later model dizzy's have a sheet metal oiler you pull open and dribble in a few drops of engine oil .
    I hope this helped .
  10. ol' chebby
    Nate's mystical magical citric acid formula......
    As far as simple radiator and cooling system cleaning , there's a whole deal you must do by the numbers else it won't work but , Citric Acid Powder does the trick , about three pounds of it mixed in distilled water then drive it an hour or so , drain and be amazed at how much black crud somes out .
    First thing though , you must flush the cooling system untill it's clean then run some non sudsing detergent in it for a day (Think 'SHOUT' etc.) and then rinse that all out , I stupidly tried to cheat and I used liquid Tide , boy howdy ! it took me a week of flushing several times a day to get all the suds out of the water jacket...
    I put the Citric Acid Powder in my radiator and then I drove it to work and let it sit all day , the amount of crud that came out the drain cock was incredible and I had to drain & re-fill it a dozen times before it'd stay clean driving it for over 30 minutes on the open road....
    also on this thread....
    https://talk.classicparts.com/showthread.php?t=6910&highlight=citric+acid+flush
  11. ol' chebby
    The new **^^^%*%&%%#@# temp guage is doing the same thing! It will rest just below the 180 mark, even when filling with cold water from the hose after a good flush. It reads 220-240 pretty quickly.
  12. Zig
    Mine hits the 220 mark pretty quick, also.
    When doing this flush, I guess it would be good to do it without the thermostat so all the crap can get by?
    I'd check the original thread on this, but my dang computer is running so slow it's not funny!
  13. ccharr
    run your virus check and clean out the history of your surfing, etc., control panel, to internet options to browsing history to delete and then make sure all your pass words are written down, to yes all, see if that helps some.
  14. ol' chebby
    Where might I find such mythical citric acid powder? Everyone I have asked looked at me as if I were a looney......or maybe I did.
  15. vwnate1
    Cooling System Cleaning
    NO ! . it will work better (with any cleaning agent) if you run it up to temperature .
    I bought my Citric Acuid Powder from a baking supply place in San Bernadino , candy making suppliers also sell it , Flea-Bay etc.
    Some candy & baking supply places call it " Sour Salt " .
    I hope this helps , it really does work well .
  16. Zig
    Well...
    Asking for sour salt DOES sound a bit better than asking for acid. :rolleyes:
    Thanks, Nate! I just thought that the crap might lodge in and around the thermostat. I surely don't mind leaving things alone, but with the heating problem I seem to be having, and the fact I let the it set for @ 4 years, and the amount of crusty, scaly stuff I found inside the water pump, I figured this treatment sure wouldn't hurt!
  17. ol' chebby
    Just for you, Zig(and the rest of you whos' trucks aren't on the road yet) so you won't have to sit there and make engine sounds anymore....
    (video)
    Put it on a big screen in front of your truck.
    And a few shots of the undercarriage...
    I greased everything, tightened all nuts and bolts, tightened the rear brakes, checked fluid levels and inspected everything underneath.
  18. Greg_H
    Greg_H Member
    A little off topic but I like the 68 Charger in front of the last picture.
  19. GLRnTX
    GLRnTX Member
    Helotes, TX
    I love the sign above the door!
    Greg
  20. ol' chebby
    You'll love the rest of the shop. I'll try to get pictures.
