How to install Pertronix points eliminator module
Discussion in '1947-1954' started by ol' chebby, Nov 23, 2012.
  1. Vigilante
    Vigilante Member
    Jacksonville Fl
    sounds doable
    Timing
    Yes Martinus ~
    Same as any other time you replace the contact points or remove & replace the distributor , the timing must ALWAYS be checked and adjusted .
    The last time I installed an ' Ignitor ' , the timing was 45? out so it took some fiddling before the timing was bang spot on and the rotor pointed to the correct # 1 plug wire position .
    -Nate
  3. Blueflame236
    Blueflame236 Member
    Norway
    Advize
    Nate thanks very much fore the good advice on the matter.
    A merry X-mass to you and Your famely , we wish you all the best of Luck and a good health after you finally got Your wanted neck surgery.
    I `ll make a toast on that drinking some strong Aqua vita ( water of life ) and home breewed beer.
    Prosit my friend to Your Health. Martinius
    Merry christmas !
    You're welcome Martinus ;
    As always it's very simple so just dot every " i " and cross every " t " and your Vintage truck will run better than everyone else's , even if it's the dreaded and embarrassing Brand "F" :rolleyes: .
    Enjoy your Aqua Vita , still no damn mince pie to be found here .
  5. Bill Hanlon
    Morris Ranch TX
    If you'll settle for mince cookies SWMBO made a batch. Drop me an address in a PM and I'll send a few on Nate.
  6. vwnate1
    Oops
    Done Bill .
    I replied in the wrong thread .
