Here’s the link to a stock resistor. It appears they were used through 1959. On all stock installations I've seen it's usually mounted on the firewall near the coil.
http://www.classicparts.com/1947-59-Ignition-Resistor/productinfo/53-911/
Here is the Mallory offering. If you’re going to use the Unilite, I’d recommend going with the Mallory resistor since I think the resistance is different from a stock Chevy.
http://www.summitracing.com/parts/MAA-700/
If you haven’t purchased the Mallory distributor yet, I’d highly recommend doing a Google search on Mallory Unilite problems, resistor, troubleshooting, etc. There are a lot of threads covering problems with this ignition. I had one about 20 years ago and spent many months replacing almost everything in my engine trying to figure out why it ran so badly. I casually mentioned it to a racing buddy, and he immediately recommended I junk the Unilite and give the module to someone that raced with them, since they fail all the time.
I immediately switched to a stock HEI and have never had a bit of trouble since. Some web threads seem to indicate the newer models are better than the early versions, but if it were my money I’d do something else.
It seems the MSD system is most popular with racers, and for street driven vehicles the answer is either a Pertronix kit, or a stock replacement HEI. Both the Pertronix and HEI are completely reliable. The Pertronix is often preferred in V8 applications because it fits under the stock cap and retains the original appearance. I believe the following link is for the correct kit for a 292 Chevy, but this should be confirmed before spending money, if this option is of any interest.
http://www.summitracing.com/parts/PNX-1162A/
