In final steps of rewiring and .....
Discussion in '1947-1954' started by Haasman, Oct 23, 2023.
  1. Bill Hanlon
    Morris Ranch TX
    Should work.
    Old, fat and tall guys like me would rather not be working under the dash though.
    vwnate1 likes this.
  2. Haasman
    Haasman Member
    N. CA, south of SF
    Happy to report it works. Really think park/running lights with head lights is good idea these days.
    vwnate1 likes this.
  3. Bill Hanlon
    Morris Ranch TX
    I just realized there is one flaw in the way you wired the jumper vs. the way I suggested with the diode. If you just pull the light switch to the first position (parking lights) the headlights will be on as well. If that doesn't bother you leave it like it is. If it does bother you replace the jumper with a 5 amp or higher current diode.
    vwnate1 likes this.
    RE : crappy Chinese insulator pads in repop bulb holders/sockets :
    I save the old fiber insulators and use them over the new Chinese ones, this gives you perfect alignment of the contacts and increases tension on the spring .
    Adding dots of solder to the paper thin copper contact buttons is wise too .
