Installing a C-Notch
Discussion in '1947-1954' started by Ricos54, Jan 7, 2014.
  1. Bilbo
    Bilbo Member
    Magnolia, Texas
    Nate, That's a really scary story. Thank You for sharing, seriously! Fairly happy ending, too. Those kinds of experiences should only be learned 'second hand'. We never want to learn that stuff ourselves. Thanks Again.
  2. Lakeroadster
    Lakeroadster Member
    Central Colorado
    Towing, and trailers, can be very dangerous. A big reason so many folks, and so much property damage occurs is due to the lack of regulations. I wouldn't say I am a "regulations kind of guy", but we have all seen people pulling trailers, trailers that would be scary to use behind a lawn tractor in a yard, let alone running 80 mph up the freeway. Hitches are the same way.
    I stumbled upon this a few years back... http://www.dangeroustrailers.org/
    Safety knows no season !
    That's a good site there .
    Imagine how I'da felt had that little boy died on my watch .
    Safety regulations are important and I goofed , helping a buddy who's tow rig wasn't set up to have safety chains .
  4. 50 Chevy LS3
    50 Chevy LS3 Member
    Indiana
    The regs. already exist.
    The problem is, quite often, LAW ENFORCEMENT PERSONEL are looking for easy revenue. They don't want to get dirty looking at Joe suburbanites homemade junk trailer. That is unless the problem is so obvious a kindergartener would see it. I'm glad to hear Nate's story ended well. I'm beginning to think I've seen everything on this nations highways. I'm not bragging because alot of it I wish I had never seen. Can't get some of the images out of my head.
  5. vwnate1
    Mechanized DEATH
    I'm with you Steve ~
    I wish I could get some of those accidents and carnage out of my mind .
    Remember this whenever you think " un regulated anything " is good .
    It might be YOUR Grand Kids that get maimed , crippled or killed next time :eek: .
  6. Ricos54
    Ricos54 Member
    CA
    Been working on my rear suspension before putting the caps on the c notch. This is what I decided to make to support my rear end :D
    [​IMG][/URL]
  7. Lakeroadster
    Lakeroadster Member
    Central Colorado
  8. Ricos54
    Ricos54 Member
    CA
    Thanks man, the pan hard bar is on the bottom diagonal from the left front it go's to the back on the right bracket. If you look real close you can see the connections. I was told that is the best way to have a pan hard bar because it does not allow the rear end to move at all. I haven't put it on because the one I got was to short so the guy had to remake it, I should have on either Friday or Monday.
    I also put the caps on last night.:cool:
  9. Lakeroadster
    Lakeroadster Member
    Central Colorado
    In front of the axle, or behind the axle?
    I'm old... I get confused easily ;)
  10. Zig
    I have no idea if what I'm looking at is safe or right, but I love what I'm seeing! Thanks for the pictures/updates! Can't wait to see the painted version! I love the way you directed the exhaust, also!
  11. 50 Chevy LS3
    50 Chevy LS3 Member
    Indiana
    Lakeroadster, I think the track-rod mounts between the lower four bars from front left side to rear right side. TCI does their four-bar kits this way, I think our hosts kits are also made this way.
    This way of mounting (at about a 40 degree angle) looks OK, but I wonder if it is as strong as a panhard bar. In the event of a near "loss of control" sideways skid, there would be massive pressure on either design. A heavy-duty panhard bar seems like a better option.
    Track-rods on heavy-duty trucks are mostly mounted 90 degrees to the frame rail.
    I'm no expert, what do you guys think?
  12. Lakeroadster
    Lakeroadster Member
    Central Colorado
  13. Ricos54
    Ricos54 Member
    CA
    Lol yeah, Here's a picture of it. My PHB should be here Monday and I'll put some pic's up.. A custom builder I talk to said this setup with the pan hard bar was his favorite. I'm told the rear end won't go anywhere setup up this way.
    And thanks Zip, so far I'm very happy with my choice's and the way it's turning out:)
    I've also been boxing the c notch in
  14. Lakeroadster
    Lakeroadster Member
    Central Colorado
    Looking good Rico.
    Your making me want to go cut something up so I can fab. something up :eek:
    Nice job on the boxing plates.
    The panhard bar isn't a panhard bar.... I think the correct name for it is a diagonal link, 1/4 mile drag racing technology, very interesting. Do me a favor and take a picture of the diagonal link bracket that attaches to the lower front 4 bar bracket see circled item below. I am curious as to how it rotates and how big the fasteners are? Hope you aren't getting tired of me wearing you out with the panhard bar / diagonal link Q&A. I'm an engineer... when I see something I'm not used to I want to take it apart, measure everything and then run calculations to analyze and understand it. It's an affliction.....
  15. Ricos54
    Ricos54 Member
    CA
  16. Lakeroadster
    Lakeroadster Member
    Central Colorado
    Thanks Rico, those photos are great. I really like this set-up!
    I see there are nylock nuts. Do you leave the bolt through the 4 bar a bit loose to allow the diagonal link bracket to pivot, or tighten it hell-for-stout and use the heim joint to take up the suspension travel?
    Just curious how the manufacturer recommends the install.
  17. Ricos54
    Ricos54 Member
    CA
    Thanks I'm glad you like it, you don't know how long I research and went back and forth about which rear suspension to buy! As far as I know with the Locking nuts you just tighten each other tight and then I will put some Loctite on the nuts that tighten up to the diagonal bar and then the Heim joints work with the four link to move up and down with the shocks this is what causes the rear end to stay in one place.:cool:
  18. Ricos54
    Ricos54 Member
    CA
    I finally got my diagonal bar and here it is in place :)
    Now I have plenty of room to run exhaust all the way to back!
  19. Lakeroadster
    Lakeroadster Member
    Central Colorado
    Looking good Rico.
    I'd like to model the diagonal link in AutoCAD Inventor and run a stress analysis on it, just for $hits and giggles.
    I've read some negative stuff on the internet about using diagonal link on the street, like here: http://67-72chevytrucks.com/vboard/showthread.php?t=187382
    But I also see a bunch of folks selling them for street use.
    To me it just seems to reason that with the long diagonal bar there should be some pretty large loads at the ends of the link, and pretty large buckling loads on the link itself. I've been wrong many time before though (ask my wife) so the analysis should help me wrap my head around what the loads really are.
    If you're up for it, could you get me some dimensional information on your rear suspension?
    A (see photo below)=
    B (see photo below)=
    C (see photo below)=
    D (see photo below)=
    E (see photo below)=
    Four link bar diameter =
    Four link bar thickness =
    Four link heim joint through bolt diameter =
    Four link heim joint thread diameter =
    Diagonal link bar diameter =
    Diagonal link bar thickness =
    Diagonal link heim joint through bolt diameter =
    Diagonal link heim joint thread diameter =
    Thickness of diagonal link bracket that attaches to four link bolt =
  20. 50 Chevy LS3
    50 Chevy LS3 Member
    Indiana
    I'm real interested in this, Lakeroadster. This is exactly what I hoped you would do.
    I'm getting real close to being done with my cab and starting to plan the rolling chassis.
