Is it Worth rebuilding if not original engine on truck
Discussion in '1947-1954' started by Neto84, May 23, 2019.
  1. Neto84
    Neto84 Member
    I’m a rookie working on cars and trucks I’m glad I found this site a lot of good info
  2. Guest5979
    Guest5979 Guest
    You engine looks clean should run well they sound like a sewing machine at idle slight tap tap tap don’t trip out (I did) when the distributor moves back and forth when you push on the gas pedel I see duel exhaust so split manifold
  3. Neto84
    Neto84 Member
    Look at what I found on the last pistons
    What can that be
  4. Neto84
    Neto84 Member
    You should hear it now it sounds way better than what it did that’s just replacing a few things next is a tune up
    It starts and stays on but once I try to go in gear it shuts off that’s where I’m stuck trying to figure out why
  5. Guest5979
    Guest5979 Guest
    Could be the float In the carburetor you said you rebuilt it maybe not enough fuel the experts here will chime in with a solution
  6. Neto84
    Neto84 Member
    Ok good thanks for all the info so far
  7. Neto84
    Neto84 Member
    Yes I have split manifold
    My 235
  8. Guest5979
    Guest5979 Guest
    Just a thought is the plastic piece and gasket that’s between the carburetor and manifold on correctly or new old one might have cracks that aren’t visible creating air leaks
  9. Neto84
    Neto84 Member
    Are you suppose to remove the old completely it is stuck and it’s all damage I ended putting the new one on top of it what can I use to remove the old one completely
  10. Guest5979
    Guest5979 Guest
    I would put a rag in the manifold hole block anything from falling in scrape it good not to gouge the metal
  11. Neto84
    Neto84 Member
    Thanks bro I will do that next week I go back to work tomorrow thru wendsday . What does your schedule look like how soon you want this done
  12. Neto84
    Neto84 Member
    Do you have a welder?
  13. Bill Hanlon
    Morris Ranch TX
    Why are the last 3 rocker arms white? Look like they have powder on them.
  14. martin3493
    martin3493 Member
    If the engine is durable and will work for long time, so i would suggest to rebuild it, i had ford 1996 diesel truck that engine was good so i rebuild totally now i am using that for roadside service near me, i have been using that for 2 years and working great.
