king pins and more
Discussion in '1947-1954' started by Guest5979, Feb 16, 2013.
  1. Blueflame236
    Blueflame236 Member
    Norway
    Result !
    I am cureous how steering works after you changed the pins ?
    Martinius.
    King Pins
    Well ;
    If you jack up the front end and adjust the wheel bearings to zero play , then you can rock the king pins for testing by grasping at the very top and very bottom ~
    Most unrestored trucks will have from 1/8"~ 1/4" of side to side play when measured at the bottom tread center .
    What this does is : allows the truck to wander aimlessly on smooth roads and follow cracks suddenly on bad roads (dangerous & scary) .
    It also causes rapid tire wear and increased steering effort .
    I hope this helps .
    Whoo boy ~ I' suffering a seriously bad cold and I think the meds just kicked in so if none of this makes sense , I'll fix it later....
