Kingpin replacements
Discussion in '1947-1954' started by dorcutt, Dec 6, 2017.
  1. dorcutt
    dorcutt Member
    Keep the truck in VT
    Got my king pins out today, the pins came out with juSt a little bangin but I had let them soak quiet a bit My next question is how do I know if I need a replacement kit or an oversize kit?
  2. coilover
    If the bushings were not worn all the way through to where the king pin was contacting steel then replacements will be fine. If there is steel on steel contact (wear) the you may have to use over size.
  3. dorcutt
    dorcutt Member
    Thank you. I suspect not as there was only a slight movement when checked, enough to fail inspection.
