Lakeroadster
Nice work indeed and great photo-documentation...now teach me how to post photos, like you have done. Great job!
PM sent...
As always John nice work..![]()
The smilley looks as if he been sniffing fumes...![]()
The guys at Repop talked a good game but never followed through with their commitment.
On three separate occasions I called and talked with the production floor foreman. He said they would send me new fuzzies, free of charge, to replace their defect parts.
They never did send them. As they say, a fella's only as good as his word.
Bottom line is the clips are in the wrong place, from the factory. If they had sent new one's I am betting they would be wrong too.
I contemplated removing the fuzzy's to modify them. Basically using a grinder or cut off wheel to trim down the bottom of the steel part of the fuzzy to achieve the correct window vertical location when rolled up. But to do that you'll have to remove the glass, remove the fuzzy, and you can bet more of the clips will break off when it is removed. Pi$$ poor, by any measure.
Repops products are typical of most aftermarket parts... look similar to OEM, the fit and finish is "reject" quality, install reveals issues, customer service is lacking.
Reject quality? I was told that back in "the day" replacement body panels from "GM" were rejects from the factory floor, basically defective or damaged parts. They were stored and sold as replacement parts. That's what I mean by "reject" quality.
Your interior looks great, I can't believe its only an aerosol paint job!
Is that the factory steering column with an aftermarket wheel?
The Grille March 2010
On the Custom Classic Trucks website I saw a photo of stock grille with stainless bars (see the first picture below). Very clean... I want to replicate that look.
First step was to cut out the stamped steel mesh. I used my air grinder and a 4" cut-off wheel.
Next was fab'g. up some mounting brackets for both sides out of 1" angle. These were drilled for (5) 3/16" dia. stainless tubes.
Next step is to make a mounting bracket for the center and then procure some stainless 3/16" tubing.
I checked your descriptions and pictures, great job very nice work and truck....
