ok i was just wandering if anyone could tell me if i could fit 33s or possibly 35inch tires under my 93 z71 if i just put 3 inch blocks in the rear and run my torsion bars up in the front. im just runnin 31s right now. thanks for any info.
You can run 33s(285/75R16 on stock wheels) with a little crank on torsion bars. To run 35s, you would have to max out your torsion bars, which I don't suggest, because it puts extreme angles on your cv axles, which causes them to break, plus you would still have to do some trimming up front. You should join, or at least check out Full Size Chevy.com. It's a great forum, you can get lots of help for and show off both of your trucks. If you do join, I'm on there as Blue Bowtie. Hope this helps.
