Master Cylinder
Discussion in '1960-1966' started by parkbro, Nov 24, 2015.
  1. parkbro
    parkbro Member
    North Carolina
    I need to replace my Stock Master Cylinder and would like to replace the original Single Reservior/Single Line with a Dual Reservoir/Dual Line (see insert) Has anyone ever made this switch? If so what Year/Model Master Cylinder did you use? I want to make sure things line up to Firewall and Brake Pedal Rod Works. Thank you.
    ironman3452 likes this.
  2. sleepysal
    sleepysal Member
    Before I did my disc swap I split my lines and used a master cylinder off of a 67 Impala . It was an easy swap .
    You need to undo the rear brake line from the tee fitting that connects the front and rear brake lines. Plug it and use a coupeler and new brake line to extend the rear line to the new master. I was able to reuse my pushrod on my 60
  3. ironman3452
    ironman3452 Member
    New Mexico
    thanks for the up date.
