my 52 project
Discussion in '1947-1954' started by 1952, Dec 15, 2013.
  1. 1952
    1952 Member
    Just as a note the 235 block has gm stamped in it and I wonder if there is any difference between that and a chev block
  2. 1952
    1952 Member
    some shots of the castings
    1 is of the block and the second photo is of the head
  3. SinclairChevy
    SinclairChevy Member
    Keokuk, Iowa
    If you have a 235 c.i. engine, it's a Chevy motor. I believe the GMG engine has a 228 c.i. displacement.
    Damon
  4. Bill Hanlon
    Morris Ranch TX
    Bilbo: tell him how much better my 228 sounds than your 235 does. ;)
  5. 1952
    1952 Member
    engine block and the casting number is 3738307 which I checked out to be a 1958 235 cu inch but with the gm stamped on the block I wondered if there was any difference
  6. Bilbo
    Bilbo Member
    Magnolia, Texas
    HuH? What'd you say? :rolleyes:
    Yeah, I thought Bill's 228 was considerably quieter than my 235... Lifter noise from mine.
    Bill, I spent another 2 1/2 hours today and finished my Trique Latch installation. They work really well. Thanks, Russ, (ol' chebby)
    Thanks, Bill Hanlon, for the help. Really appreciate the second pair of hands, and good company.
  7. 1952
    1952 Member
    latches
    Did they go in fairly straight forward ?
  8. ol' chebby
    Follow the instructions. They are one of the few aftermarket kits that actually fit and work With little to NO modifying.
  9. Bill Hanlon
    Morris Ranch TX
    We (Bilbo and me) followed the instructions and did pretty well. Only thing that we did wrong (it was my fault) was mounting the right side striker on the left door. The instructions did not indicate which side was which and I tried to reason it out based on one side of the striker plate is curved and I assumed the curved side of the striker should line up with the curved edge of the door. Wrong!
    Russ: How do I order a set from you? 52 GMC 3/4 ton.
  10. vwnate1
    Engine Identification
    Those are CASTED not stamped and yes , there's a HUGE and important difference ! .
    Casted # & letters are put in when the part is casted before any machining .
    Stamped (like near the dizzy) numbers & letters go on after the part is completely manufactured .
    GM is The General Motors Corporation , parent owner of the CHEVROLET and GMC Divisions .
    No possibility that 235 has anything to do with GMC .
    The road draft tube look interesting .
    Don't EVER let that starter out of your sight ! rebuilders will *instantly* chisel off that unobatanium DELCO tag .
    I like the knobs , especially the original bakelite one but , I'm not happy there's not manual choke and throttle... :p .
  11. Bilbo
    Bilbo Member
    Magnolia, Texas
    Bill, PM Russ and give him all the information about your truck and he'll be able to fix you up. ;)
    Taking Clarabelle out tomorrow for a few errands. Doors to remain closed at all times while moving! :D
  12. 1952
    1952 Member
    bumper and slash apron on, rear fenders on.
    running boards next
  13. Zig
    WOW! That looks B-E-A-U-T-F-U-L!!!! :cool:
  14. 1952
    1952 Member
    thank you Zig
  15. SinclairChevy
    Keokuk, Iowa
    Paul's right... that really looks fantastic! Did you custom-fabricate the rear splash apron, or was it a stock option?
    Thanks for sharing!!
    Damon
  16. 1952
    1952 Member
    I don't know if it was a stock item but I ran across it on chev of the 40 website (our sponsor does not offer it) I wanted to fill in the void and thought this would do
  17. vwnate1
    Looking Good !
    Sweet looking rig there ! .
  18. 1952
    1952 Member
    slowly but surely
    1- put the running board body cab seal and running boards on. I thought I would put welting between the running board apron and fender as well as between the cab and apron
    2- got the front splash apron and bumper on but not to happy with the fit of the apron as it has a big gap on both edges
    1952 Member
    upper door springs
    OK I am having my moment today as I am looking at these upper door springs and the door hinge and I cant wrap my head around these.
    How in the h do these go in, anyone with directions please :confused:
  20. peabo
    peabo Member
    North Vancouver, Canada
    http://www.youtube.com/watch?v=aEoBFw8kaTE
    Bam!
    Jeff
