New Guy Saying G'day
Discussion in '1947-1954' started by Aussiechevy51, Mar 2, 2013.
  1. Aussiechevy51
    Aussiechevy51 Member
    wow...that is amazing. i would never have guessed that it was stainless. not that i had looked too closely at it. i am impressed
  2. Blueflame236
    Blueflame236 Member
    Norway
    Engine size determination !
    That looks very much a 216 CID engine.The engine cover has the 2 bolts in top. But if you want to determine the block there should be a block number at the left side near the ignition device and cylinder top number aswell on the other side. Some of the guys here can help you to get the excact made of your engine .
    Good luck Martinius.
  3. Aussiechevy51
    left side standing from front? as in starter motor side?
    i got home last night so i will have a look at the numbers some time today and post them.
  4. ol' chebby
    Left and right are determined as if you were sitting in the vehicle. Right side would be YOUR driver's side, or the right side of the truck.
  5. vwnate1
    Your Engine
    ...Is clearly an early 235 CID unit , I gave a BIG sigh looking at your pix you Bucky Lugger ~ where are the normal gaping rust holes ?! :confused: .
    You have the beginnings of a shop truck there or , were it mine , a stone reliable easy to fix , cheap to run , long lasting Work Rig.....
    The choice is yours ~ save everything you take off especially the hardware and those two cute little sheet metal 3/8" tubes you'll find after it's all done ~ they go inside the rear ball housing mounts and are UNOBTANIUM these days .
    NICE TRUCK ! .
  6. Aussiechevy51
    hey guys, found an engine block number but no head number, must be under valve cover????
    engine number is 'XCR476362'
    what do all these mean?
    Thanks nate, she is a good strong truck, was shedded most her life. now her time has come to shine once again.
  7. Blueflame236
    Blueflame236 Member
    Norway
    Decoding block information !
    What series is your truck a 3100, 3600 or 3800 stakebed truck ? Do you know if the installed engine is the original one ?
    Found some information wich might be of help to decode your engine. scroll all the way down at this page as it shows the numbers location. http://67-72chevytrucks.com/vboard/showthread.php?t=356268
    http://chevy.oldcarmanualproject.com/models/engine.htm#51eng
    http://www.51classicchevy.com/1951-six-cylinder-engines.html
    Six Cyinder: Number is located at the passenger side of the block behind the distributor. http://www.adchevy.com/tools/castinglookup/?castingnumber=XCR476362&submit=Lookup
    http://www.adchevy.com/info/article/chevy6castingnumbers/
    Engine ID Code Example: V0101CLJ - (V = Plant, 01 = Month, 01 = Day, CLJ = Engine Suffix Code)
    Code Engine Plant:
    F Flint (Motor) K St. Catherines, Ontario V Flint (Engine) (McKinnon Industries Canada)
    M GM of Mexico
    S Saginaw Service
    H Hydramatic
    T Tonawanda
    Martinius.
  8. Aussiechevy51
    martinus
    the number i found is stamped on the machined surface next to where the dizzy comes out of the block. couldnt find any casted numbers as seen in pics on ->(http://67-72chevytrucks.com/vboard/showthread.php?t=356268)
    makes me thinks 216 engine
    truck is chev "1420" 'Aussie built truck' not sure how this converts to US truck numbers, but is 3/4 Ton payload from old REGO certificate and vehicle loading plate on firewall
    :)Frustrated:)
      File size:
      103.3 KB
      393
  9. Blueflame236
    Blueflame236 Member
    Norway
    Aussy decoding source
    I am 98 % shore the engine is a 216 CI engine.
    The stakebed sizes are mentioned in US "old chevy manuals" web side. Look it up and determine your truck model at first !
    That changes eveything as it is licence produced in Australia. Any chances there is a chevrolet web source or chevy truck club you could contact ?
    Martinius.
  10. Aussiechevy51
    martinus
    i am 98% shore of it being 216Ci also
    i've done a lil digging and...
    1420 series track convert to Australian build and Canadian built load numbers. 1420 does convert to US 3600/3/4ton. i have also found 1 website so far for Aussie built chev trucks and there seems to be a fair bit of literature. i will read some more over the next day or so and post my findings.
    til then
    jed
  11. Blueflame236
    Blueflame236 Member
    Norway
    classic vehicle sources Australia !
    Some sources:
    Its obvious that Holden GM car compagny in Australia is the main source where the truck whas reassembled and given the 1420 series number fore a commercial truck. I know that the american Heritage center could help out with some historicall facts but better would be to contact the Heritage center in your beautifull Australia and ask them your questions.
    http://www.hcvc.com.au/
    http://www.arthc.com.au/
    http://www.gregwapling.com/hotrod/chev-trucks-47-55/holdenchev.html
    http://history.gmheritagecenter.com/wiki/index.php/1948,_The_First_Holden
    http://www.hcvc.com.au/forum/YaBB.pl?num=1270466398
    http://www.ozrodders.com/forum/viewtopic.php?f=2&t=45093
