New Here - Separating trans from motor??
Discussion in '1947-1954' started by Morgan, Feb 11, 2023.
  1. Morgan
    Morgan Member
    Temecula
    Hi Everyone,
    I just inherited my father in laws previous project and started work on it last weekend.
    The rebuild had been started, but only for fit assembly to be torn apart again for paint etc.
    Once I got the truck back home I started to notice certain details not making much sense, and was left with a ton of hanging question marks as to what had been done, what hadn't etc. So I made the decision to pull it apart and start from 'scratch' so to speak.
    The truck has already been Mustand II'd/frame partially boxed, and currently has (had) a 302 with a 3 speed auto trans. My plans for the truck are a tad different, so out comes the drivetrain.
    Motor/trans are out and I was trying to separate them but keep getting hung up with about a 1/2 gap. My guide pins are clear, all? the hardware is out, and I have a gap going, but cant pull the trans from the motor...am I overlooking something super easy that will allow me to separate those 2 units...I'll post some photos here shortly, but now my priority is getting these apart and continuing the disassembly.
  2. Bill Hanlon
    Morris Ranch TX
    302 like six cylinder GMC engine or 302 like Camaro Z28 engine?
    vwnate1 likes this.
  3. Morgan
    Morgan Member
    Temecula
    Totally spaced on that detail. inline 6 gmc
    thanks!
    vwnate1 likes this.
  4. Bill Hanlon
    Morris Ranch TX
    Next question: Is this "3 speed auto trans" a later model like a TH350 or TH400? Reason I ask is because if factory equipped with an automatic transmission, 302 engines came with a 4 speed, "dual range" HydraMatic. Look around the outer edge of what you would call the "torque converter" on a more modern tranny like a TH350 and see if there are a bunch of bolts (18) holding it onto the flywheel. If so, yours is definitely a dual range HydraMatic.
    If it is a dual range HydraMatic all those bolts must be removed to separate the tranny from the engine.
    What is the year, make and model of your truck?
    I've left you a PM.
    vwnate1 likes this.
  5. Bill Hanlon
    Morris Ranch TX
    Morgan: Give me a call at 713-468-6417
    vwnate1 likes this.
  6. vwnate1
    Morgan ;
    Don't leave us hanging .
