New truck, old guy
Discussion in '1947-1954' started by Bill Hanlon, Mar 3, 2013.
  1. Coach529
    Coach529 Member
    Jamestown, ND
    Nice looking truck!!
  2. Kens 50 PU
    If it's like the Chevy, it should just pop off with a little help from a screwdriver. Here's what the back of the Chevy horn button looks like.
    Ken
  3. Chiro
    Chiro Member
    "New" truck
    Good on you. I wish you all the best, congrats.
    Andy
    Buck teef !
    Way to go Bill ;
    That looks and sounds like a good 'un .
    Retirement eh ? congrats , I'm due in 2016 if I can hang in that long .
    How's about some underhood pix and maybe a .wav file if how it sounds ? .
    After you remove the steering wheel & polish the slip ring , gently burnish the horn's contact points and it'll toot gangbusters , IIRC a '52 has a horn relay , non ? .
  5. Zig
    Why yes, yes it does!
    And the back of a GMC horn button looks just like the back of a Chevy horn button. :p
  6. Herb Rockwell
    Herb Rockwell Member
    Congrats on both accounts. Did you find your '52 in Texas? Disregard the link I sent you on the '55 Chevy. That was before I knew you got the GMC.
    Nice Choice! Herb
  7. Bill Hanlon
    Morris Ranch TX
    Got the horn button off just as you guys said. The spring loaded horn contact that passes through the steering wheel was very corroded on both ends as was the point that the contact touches the horn switch. Cleaned them both up but it still didn't work. Used an ohmeter to find the the horn switch itself had way to much resistance. Unfortunately I'd probably ruin it opening it up, so I'll just order a new one from LMC as our host doesn't seem to have one for a '52 in their catalog.
  8. Bill Hanlon
    Morris Ranch TX
    Yes, about 15 miles north of home.
  9. ctzr1
    ctzr1 Member
    De Pere, Wisconsin
    Cool Another Long Motor GMC
    Welcome to the club
  10. Zig
    Well, pictures of that motor would be nice to see... :rolleyes:
  11. vwnate1
    Sure , Go Right Ahead ~
    Just beat up on us poor old Chevy guys whom mostly suffer L O N G Motor Envy :rolleyes: .
    We can take it , never mind the sniffling you might hear as those roaring high nickle motor pix load up :p .
  12. Zig
    Come on, Bill~~~~
    Where are the other pictures??? :confused:
    We need engine compartment and interior shots!
    You *are* retired now, so entertain us, please?
  13. vwnate1
    Patience , Zig
    He's prolly still giggling thinking about how that L O N G M O T O R pic hit us BOW TIE guys ! :D .
  14. Zig
    You mean like this one???
    Sorry, I couldn't resist! :D
      File size:
      127.6 KB
      379
  15. Zig
    Before anyone spends any unnecessary time trying to figure what's up with my picture, I have the old vacuum advance line kinda laying in there and the water pump is off. The picture is pre newly installed vacuum advance.
  16. Bill Hanlon
    Morris Ranch TX
    Been falling down mountains with boards on my feet in Colorado with the grand daughters since 3/8.
    I ordered a valve cover gasket before I left (hope FLAPS hasn't sent it back!!) for the planned Nate-directed valve adjustment. I took the idle speed down from 600 RPM when I bought it, to the factory specified 350 RPM and you can hear a definite uneven pattern in valve noise at that speed.
    I'll take some pictures after I get the valves tweaked and the after-mess cleaned up. Maybe I can get Ken to come buy and hold a cold beer for me.
    One thing I did notice is that the manual throttle cable is unhooked. If I want to keep the 350 RPM idle, I'll probably need to hook it back up to provide a faster idle when the A/C is running. My guess is that little Sanden compressor won't put out much R-134 at 350 engine RPM.:rolleyes:
  17. Bill Hanlon
    Morris Ranch TX
    Question for Nate
    Nate: Your "hot" valve adjust procedure is on a thoroughly warmed up, but NOT running engine, correct? I understand how to make sure the valve being adjusted is fully closed.
    I remember adjusting valves on running engines with oil spitting hither and yon with a stubby screwdriver and a box end wrench.
    I'll do it whichever way you say.
  18. vwnate1
    Valve Adjustment
    Engine stationary ;
    Run it 'till it's fully warmed up then have at it ~ I like to remove the spark plugs so the engine is easier to rotate .
    What's the firing order again ? .
    Be sure you check all the spark plugs to have a .035" gap , use a wire gauge .
  19. steve
    steve Member
    Virginia
    Great Looking Truck
    Bill,
    Retirement, Great also, looking to it some day.......Flat Bed is cool.
  20. Bill Hanlon
    Morris Ranch TX
    Stopped by FLAPS late this afternoon to pick up the valve cover gasket. When I ordered (Mar 7), I told them that I would be out of town until today. Didn't make any difference. When I failed to pick it up in a few days they sent it back to the Dallas warehouse. It'll be Tuesday before I see it again.
    Just read through the Maintenance Manual. GMC recommends .012 intake and .020 exhaust clearance hot and adjusting it the messy (running) way, but I think I'll stick with Nate's way.
    Question: Should I use any "stick-em" on the valve cover gasket? If so, what kind? And glue the gasket to which surface, head and/or cover? Maintenance Manual does not mention any.
