Oil filter hoses
Discussion in '1947-1954' started by rix 48, Sep 1, 2008.
  1. Volker
    Volker Member
    Germany, nearby Leipzig
    Hi Nate, greetings from cold Germany. You said 10% of oil are filtered?. Do you know a way to improve this?. I think about to find a new way for a external filter system. My idea is a electrical oil pump between in and out of the original oil filter. It is possible? or is the quantity of oil at this point to little.
    Another idea. I drill 2 holes in the oil pan (in and out) mount a electrical oil pump and a filter and clean the oil.
    Volker
    Full Pressure Oil Filter
    Sorry Volker ~ you have to do as Bruce mentioned and drill into the oil gallerys and tap them .
    It's all detailed , uh I forget where but I'm sure Bruce will know...
    There's no reason a by-pass oil filtered engine won't last 100,000 miles .
    Just take care of it , keep it sharply tuned and always do regular hot oil & filter changes .
  3. coilover
    Anytime a barbed fitting has a plastic washer (yours are yellow) then it is a push on fit that requires no clamp. I have used them on fuel lines with 60 psi without problem. If you save them do not cut the hose lengthwise down the barbed fitting as this gives a scratch or groove for a potential leak. Cut the hose just at the end of the fitting and then abrade through it with the wire brush on a bench grinder. Any scratches will be parrallel to the barbs and not a source for leaks.
    Thanx Evan !
    We have those leyyow barbed fittings in the shop , I didn"t know why as I always use clamps...
    I asked and no one knew why the yellow plastic band .
  5. PHAT
    PHAT Member
    Nate i agree with almost all oil filters in use.Not the oil filter stock on our motors.They do not even filter 10%. It is more like a oil leak after the oil filter is wet (not even 1% i bet). If you take stock fitting off and put a aftermarket filter on most times you will see a pressure drop and than it will go back up after the filter gets wet(the filter was and after thought not a fix)The reason for that? no oil going thru the filter . Bigger lines are real bad as in aftermarket as that port was only made for and oil pressure gauge not a full blown oil leak that just dumps oil back in to the pan. Not a good deal as it does cause problems. Just for a test so you can see for yourself pull the lower line off at the block after the truck has 500-1000 miles on it....not much oil at all is coming out. If you do go after market with big fittings it is like a oil leak to the bearings. I only figured this out after building a few of these and that was by accident as i was looking for a port to plumb the turbo charger too. The best thing you can do with these motors is get a newer valve cover with out the openings and put a PVC on it and ditch the road draft tube(were i put the PVC in the block. Stops more dirt/water from getting in than the filter could ever get ride of.
    If anybody is getting ready too build a motor i think i can scare up the pixs on how to do a modern filter that will work very well. It just wont look factory. Takes about 1 hour and a hand full of hand tools......pretty easy. You know i drive my motors a lot of miles nate. I get way over 200,000 on bearing now. Before i had a set in the glove box LOL 75k is all the rods would go maybe 80k to 100 on lower mains.
  6. Thunder54
    Thunder54 Member
    Port Arthur, TX
    Or green trucks
    If you add AC your 235 can look like this.
    Jim :D
  7. PHAT
    PHAT Member
    Mine does look just like that! LOL same color same a/c pump and alt placement. Only thing diff it has a 4412 holley carb......Well it dont run a stock filter anymore .A/C was the best 25 bucks i ever spent on that truck
