parts 63-66 chevy
Discussion in '1960-1966' started by 64shortbed, May 12, 2008.
  1. JustaTruck
    JustaTruck Member
    Elizabethtown, KY
    Hubcaps
    I see one hubcap. What shape is it in and are there others?
  2. 64shortbed
    64shortbed Member
    scott city ks
    the turn sigal bezels are in good shape lens were broke i did not see that at first housings in good shape i have part of the wiring for them. hub caps are in good shape maybe a couple dents have not looked at them to close they are painted white. it has 2 of them. as far as the wiper/washer i think ill keep it i dont know if it work or not.it should wor in my 64 gmc. i do have the 2 i took out of my gmcs though if interested.
  3. JustaTruck
    JustaTruck Member
    Elizabethtown, KY
    Parts
    Can you send pics of the hubcaps?
    What about the instrument bezel and lens?
  4. 64shortbed
    64shortbed Member
    scott city ks
    ill try and get some pic today and post them for you
  5. jmk_first1966
    jmk_first1966 Member
    Parts
    is the steering wheel any good?
  6. 64shortbed
    64shortbed Member
    scott city ks
    it may have a couple of cracks ill have to run out and look at it ill let you know
  7. 64shortbed
    64shortbed Member
    scott city ks
    justa truck i have not made it out there yet ill try tomarrow
  8. jmk_first1966
    ifs its not to bad let me know a couple cracks is fine, if you still have the horn button as well let me know, also if you have the turn signal parts and the ash tray i'm interested in those as well.
    Thanks:confused:
  9. ka7qgd
    ka7qgd Member
    Portland, Or.
    Do you have a right side vent window? The lock gizmo is broken off on mine.
  10. 64shortbed
    64shortbed Member
    scott city ks
    justa truckhere are the pics of the hub caps one is good the other is dent but a little time could be stairted. and the turn signal bezel are like you see them alittle scuffed but not bad.
  11. 64shortbed
    64shortbed Member
    scott city ks
    justa truck here are more pics of insterment panel for you.
  12. 64shortbed
    64shortbed Member
    scott city ks
    jmk first1966 here are some pics of the steering wheel for you there are a few chips around the horn button part. and ash tray needs new handle. let me know.i dont have any good turn signal parts sorry. and i do still have the horn button you see on this post. let me know
  13. 64shortbed
    64shortbed Member
    scott city ks
    ka7qpd the pickup you see has the same problem. i well have one here shortly after i get started on the right side door on my 64. ill let you know when i get it out.
  14. 283 man
    283 man Member
    Bentonville,Arkansas
    Hey Mark got any good front fenders 60-66 chevy/gmc ? pictures would be great looking for good set doesnt have be perfect little surface rust ok . I can fix that:rolleyes: looking to trade you a 66 shortwheel base frame and cab good rearend no motor or trans. pick up only.. :eek:but it s got to go by June 10th.Got another 63 shortwheel base coming soon.. let me know if you interested in that trade.thans 283 man
  15. 64shortbed
    64shortbed Member
    scott city ks
    the fenders on the parts pickup you see here are shot rusted top bottom and front. the ones im using i bought rear half sections to fix them. sorry mark
  16. 283 man
    283 man Member
    thats ok thanks.
  17. JustaTruck
    JustaTruck Member
    Elizabethtown, KY
    Catching up
    Sorry, got lost in a time warp - moved.
    So, is there anything left?
    There were two hubcaps, one that looked prettry good.
    I'm also looking for a "closing panel." It's the piece of metal that holds the fender seal to the innere fender. Look inside the wheel well, if you see a strip of rubber seal keeping crud from getting to the door then you have one holding the seal to the truck.
    If you have any of these what would you need from me?
  18. 64shortbed
    64shortbed Member
    scott city ks
    sorry i have moved and any thing i didnt need for my 64 i have gotin reed of.
    thanks mark
  19. Raidersfan78
    Raidersfan78 Member
    central ohio
    rad core
    what kind of shape is the rad core, if its in good shape what do you want for it?
  20. 64shortbed
    64shortbed Member
    scott city ks
    sorry man its gone too
