BamaJohn66
I performed the power steering conversion this weekend using the Rez Eng.Bracket I purchased from Chevy Duty,It was a breeze and installed great looks like it is a factory install,The only changes I made to the directions aided in the easy install,My gear box came from a 75 1/2 ton,along with the gear box I got the steeering shaft also,my stock column has a 3/4 " round shaft all the way to the stock gear box,the directions have you drilling the old rag joint and going to great links to retrofit everything,I sinply went just above the new gearbox where the shaft is round before it turns flat/round and cut the shaft on the new shaft,the inner dia.is exactly 3/4 and slid up over my old shaft,after welding the two shafts together it looks like a factory job,no drilling rag joints or using a 3/4 drill bit to get the old shaft out of the old rag joint fitting,most of Rez instructions was on drilling and using the un-needed parts,I can take pictures if anyone is interested super easy install.
