Ranger Overdrive
Discussion in '1947-1954' started by destryrideagain, Dec 1, 2010.
  1. destryrideagain
    destryrideagain Member
    Kansas City
  2. brit 50
    brit 50 Member
    Essex England, the motherland
    Mmmmmmm
    Looks interesting, it could be viable unless you have the torque tube like I have, that would be a major problem
    Overdrive
    This looks O.K,. except it goes in FRONT of the tranny and so means significant changes to your truck , ones that'll lesave big scars if you decide you don't like it...
    I'm pretty sure Gear Vendors makes one for the back of an SM420 tranny...
    having a Torque Tube makes things *much* more difficult .
  4. Blueflame236
    Blueflame236 Member
    Norway
    Feedback overdrive.
    Hey guys
    Very intresting Thread this one indeed.
    I wrote them an e.mail to ask if it is posseble to convert it with an torque tube system and the Saginaw 4 speed conversion? I wanted to know the facts and if it will lift the driving range even moore.
    I`l back on this subject Martinius.
  5. destryrideagain
    Kansas City
    Nate you are right, the Gear Vendors one is more practical but it is $3,000 up! woooo
  6. vwnate1
    Dreaming
    $3K ?! OUCH ! :eek: .
    I guess I'll go buy another Lotto Ticket then....
  7. Blueflame236
    Blueflame236 Member
    Norway
    Ranger overdrive , answered by Greg Miller Transmission & Gear
    O.k. guys this is the answer i have got today and there might be a chance it will work ?
    Martinius -
    The cost of the Ranger is $1495. It will not care about the adapter on the rear, it bolts between the trans and the bellhousing
    Looks like it will fit. Thanks for the pics, however the pics do not, however, clearly show the front bolt pattern or input shaft. To verify: Make the following measurements on the trans;
    Dia of input shaft at splines
    # of splines
    length of input shaft measured from the front of the trans
    measure the vertical and horizontal center to center measurements of the bolt pattern where it bolts to the bellhousing.
    Diameter of the hole in the back of the BH that the bearing retainer indexes (centers) the BH into.
    Thanks!
    Greg Miller
    High Impact Wheels / Transmission & Gear
    Toll Free 888-316-2940
    www.high-impact.net
    Note: Conversions are not an exact science. Part of our service includes going over your job in detail when you place the order, and verifying the engineering to ensure you have the best engineered kit for the job using the best data we have available to us. Unforeseen variables can come up during the install: We also provide full and available technical support after you receive your parts, any questions or difficulties you might have before, during or after the install.
  8. destryrideagain
    Kansas City
    Thanks for posting that Martinius, what tranny are you running in your truck?
  9. Blueflame236
    Blueflame236 Member
    Norway
    Tranny question?
    I run a fully synchronized Saginaw 4 speed 3.11 1 st. gear with the Patricks converted short tail peace. Attached pictures.
    I found these articles very intresting, there about using the Ranger splitter in front of the SM420 tranny used in the Military Dodge. It has a Chevrolet Bellhousing wich i can see have the same mesuares as what many chevy 1/2 t. trucks have.
    Good article;
    http://www.garbee.net/~cabell/rangeroverdrive.htm
    Very good article;
    http://www.fordification.com/tech/torque-splitter.htm
    Does anyone knows if the Saginaw have the same boltpattern/distance like the SM420 ?
    Mesuared bolt hole senter/senter Saginaw have ; Vertical 6.2 inches , horizontal inches 9.1 ( attachted picture).
    What is the Dia. of the hole in the back of the Bell Housing (216 CI) that the bearing retainer indexes (centers) the BH into?
