yodaman
Hi guys,
It's been quite awhile since I seriously fooled with the old truck, life getting in the way. My trusty Sonoma finally died so I'm looking at the '54 as an alternate means of transportation. I've just about finished replacing all the brake lines and rebuilding wheel cylinders so I decided to try to fire her up. The last time I did so was about a year and a half ago. The fuel pump had quit so I used the gas can on the hood trick and let it run for awhile.
While replacing the fuel pump I had water pouring out of the block while loosening the fuel pump bolts. I drained the oil and searched old threads here and came to the conclusion that it was from rain leaking in over the years. I had the valve cover on but not bolted down. I checked the radiator and it seems to be full. I refilled the oil, replaced the points, plugs and coil. She fired up and ran fairly well. Smoked a good bit. I let it run about 30 minutes total (a few stops and starts). I was concerned that the oil gauge didn't register. i couldn't tell if oil was coming up through the weep holes since I kept adding oil (I had a hard time telling if the dipstick was reading true or if it kept smearing on the way out of the tube.) It got a little hard to start so I researched again and decided I needed to do a valve adjustment. In the meantime I decided to drain the oil, empty the oil filter and refill knowing that the block should take five quarts and the filter more.
When I first did the valve adjustment I compared Nate's instructions from Deve's site to the owner's manual instructions and noticed the book doesn't mention pulling the plugs and checking the rotor position etc. So of course, that being the easier way,was the way I tried it. Fired it up and it made alot of noise so I decided to use Nate's instructions.
Now for my questions (sorry it's so long but I didn't want to forget any clues
When I aligned the ball with the pointer and pulled the distributor cap i noticed the the rotor was not pointing at #1 but rather #4. Does this mean my timing's off?
What else should I be checking before a test drive? I plan to do a tune-up, flush the radiator and a couple more oil changes to make sure there is no more water.
Thanks,
Joshua
Thanks,
Joshua
