Seals outside the rear axle
Discussion in '1947-1954' started by wokri, Aug 20, 2020.
  1. wokri
    wokri Member
    Germany
    Hello,
    what do I have to do to change the seals on the rear axle where the rear wheel is located?
    On your answer could you discribe it step by step?
    Ask
    Wolfgang
  2. coilover
    Jack up and put jack stands under rear end.
    Take off wheels and brake drums
    Take cover off back of differential---10 bolts
    Remove set bolt that runs through the spider gear pin---about 3 inches long and has a small hex head usually 5/16 to 7/16 inch
    Remove pin and square spacer block
    Push in on axle and remove horseshoe shaped "C" clip
    Pull axle out
    Remove seal and install new one
  3. Bill Hanlon
    Even's instructions are correct for a 1/2 ton (3100/3200) truck. If your's is a 3/4 ton let us know.
  4. wokri
    wokri Member
    Germany
    It's a Chevy 3600, 3/4 ton truck.
  5. Bill Hanlon
    3600 uses a H-050 rear axle which was used on 3/4 and Chevy and GMC trucks at least into the late 1950s. I don't know where to find a maintenance manual for an early 50s Chevy truck, so I'm referencing an on-line 1957 GMC Maintenance Manual which has good coverage of the H-072, heavy duty version but mechanically the same as the H-050. I checked this on-line copy of the '57 GMC Maintenance Manual against my paper version of the 1952 GMC Maintenance Manual and they agree everywhere I have referenced below.
    Start reading here: 1955 - 1959 GMC Trucks Maintenance Manual - Models 100 - 500
    The good stuff (rear hub and bearing replacement) is here: 1955 - 1959 GMC Trucks Maintenance Manual - Models 100 - 500
    When the manual refers to a "type A,B, or C" yours is a type A (all series 150 and 250).
    There is a reference to section 2 for axle shaft removal. Look here 1955 - 1959 GMC Trucks Maintenance Manual - Models 100 - 500 for removal of H-072 axle which comes out the same way as your H-050.
  6. wokri
    wokri Member
    Germany
    Thank you Bill!
  7. wokri
    wokri Member
    Germany
