Starter trouble
Discussion in '1947-1954' started by denisf, Jun 4, 2011.
  1. vwnate1
    Good Deal !
    As spare parts availability is always a good thing .
    I was going to say he's not eccentric then I thought about my old car parts stash & decided maybe not :rolleyes: .
  2. 1951chevy1ton
    1951chevy1ton Member
    Near Sleepy Eye MN
    6 Volt starter if needed
    Hey guys, I have a 6 volt starter from a 1948 chevy 216 engine, spins real good when powered by a 6 V bat charger. Interested? my email ears are OPEN. Thanks Jerry jmath@redred.com
  3. denisf
    denisf Member
    Colchester, CT/ Clermont, FL
    starter parts
    I sent you an email. Denis
    6 Volt Starter
    THANK YOU JERRY ! .
    Adding a price would have been good along with where it's located as these things are heavy and $pendy to ship .
  5. denisf
    denisf Member
    I assume you received payment have you shipped it yet? Denis
  6. denisf
    denisf Member
    Old boy running again
    I got my starter back from the rebuilder and he did a terrific job. Replaced the armature and rebuilt the rest including new gear and all moving parts. I did buy a second used one as a back up that I will rebuild.
  7. vwnate1
    Oooo , Purty *BUT* ~
    I don't see the battery ground cable going to the bell housing like it needs to...
    I am sure it's too short so just order up a 0 gauge one that's long enough to reach the bell housing where that ground strap is bolted and attach it there , keep the ground strap too .
    Battery ground cable *MUST* be connected directly to the tranny or bell housing else it'll chew up that rebuilt starter .
  8. denisf
    denisf Member
    ground cable
    Thanks so I am to run an additional ground cable using 0 gauge wire from starter to bell housing?
  9. vwnate1
    Battery Cables
    No ~ you need the battery's ground cable to be connected from the - post of the battery , directly to the tranny or bell housing and it must be a minimum of 0 gauge .
    Connect it to the same bolt you're now using on the ground strap .
    Battery ground cables must always be connected to the drive train , not to the frame or body . this minor detail is very important .
