Does anyone know where i can find a breakdown drawing of a '66 non tilt manual steering column? I need to replace the bearings in mine but im not sure of the exact parts that 'should' be replaced...thanks yall
g.t.
theres no good pic, not even in the origanal manual. Classic parts sent me the best pic they could come up with and it wasnt what i needed unfortunatly. i will tell you this, under the hood as the column comes throu the firewall, remove the small shield, theres bearing #1. remove steering wheel and turn signal cam, theres bearing #2. sorry im not much more help then that.
