Bilbo1
- Joined
- Nov 19, 2017
- Messages
- 22
- Reaction score
- 5
- Age
- 73
I've been off the sight for, apparently too long, as my I.D. was removed by "housekeeping". Thanks to Bill H for the update on my Borg Warner T89. As a follow up to the overhaul... I know there aren't many like this out there because a manual transmission GURU that I've been working with said he hasn't seen a 'live one' like it in 50 years! He rounded up enough replacement parts, most of which are the same as a BW T85, for me to overhaul my tranny. This tranny also has much in common with the next iteration, the T90, (used in lots of Jeeps). FYI, if you have any of these three models, and need to work on it, I've got some advice for you. When replacing the input shaft bearing and shield, the shield goes Inboard of the bearing, (that's inside the transmission). If you place it outboard, as it appears to belong in the exploded view I have, the transmission will discharge oil through the 'nose cone', thoroughly lubricating the clutch disc, and all associated parts! Additionally, there is a seal available, which is for the T90, that seals between the nose cone and the input shaft of all 3 models. ( it is: Omix-Ada 18880.44, available from Amazon as one source) Without this seal, and even with the bearing shield in the correct location, my tranny still spews some oil on the clutch. Accordingly, I will be R&R ing my tranny for the 3rd time to install said seal! I must thank my transmission specialist for all his help. His name is Earl Zimmer, Located in Baton Rouge, La. [email protected] He went out of his way to help me with parts, and made himself available by phone "whenever You need help".
