RE: Upgrading to Electronic ignitio
Just buy you an HEI distributor, install it, and hook up the hot wire that did power the external coil to it. The spade connector is marked and you will probably need to add a female spade connector. There is another spade connector to connect a tach wire if you want one. You will then need to change plug wires to HEI type and you're done. no more points and condenser.
