Valve job
Discussion in '1947-1954' started by Bill Hanlon, Oct 20, 2013.
  1. ccharr
    Those are great photos of your truck and of the three of you. Thanks for sharing.
  2. JW 54
    JW 54 Member
    Cypress Texas
    Why is it that Bilbo's truck is the only one in the pictures? Looks awesome by the way. I know Bill's truck is torn down but Ken you must have drove yours to Bilbo's right? Or is Bill to big to sit up front?;)
    Hope you guys had a great day.
    Jerry
  3. ol' chebby
    I dunno, shady looking bunch. I would check all my tools and my wife's underwear drawer.
  4. Zig
    WOOHOOOO!!!!! :D :rolleyes: :eek:
  5. Bilbo
    Bilbo Member
    Magnolia, Texas
    I may have to drive my truck over to Ken's to see His truck :rolleyes: I expect to be able to do that in 2 or 3 weeks. BTW, Ken, if you think you can get your hands on a steering wheel, I'd be interested.
  6. Zig
    You're driving yours without one??? :eek:
    :rolleyes:
    Your truck looks SO good!!! :cool:
  7. ol' chebby
    You can do amazing things with a good pair of Vise Grips.
  8. Kens 50 PU
    Russ, you just got a belly-roar from me on that statement!:D Back in '71 when dad and I were restoring a '48 chevy coupe, we had a pair of vise grips clamped to the steering column and a galvanized bucket to sit on! high tech low tech!
  9. vwnate1
    Top End Works
    Not removing the pistons ? why ever not ? .
    If they all look like this , a new set of piston rings properly installed and broken in (60 seconds) will yield greatly reduced blow by and carbon buildup , more power , better fuel economy blah blah blah.....
    Plus , you might find one of those pistons feeling it's age and maybe some skirt damage or getting ready to collapse .
    It's your call but slapping a fresh head against some old worn out rings usually makes a smoker/oil burner .
    Me , I'd install a set of gapless rings from Top End Performance .
  10. vwnate1
    HMmmmmmm.......
    Buncha Old Guys and some old Truck :cool: .
    Does life get any better than this ? :rolleyes: .
  11. Bill Hanlon
    Morris Ranch TX
    1.Bottom end is quiet when running.
    2.Oil pressure is around 10 pounds HOT at idle and 50 (hot), 60 (cold) pounds at speed.
    3.If I needed to go completely through the engine it wouldn't cost much more to find and go through a 270 or 302 that would bolt right in place.
  12. vwnate1
    Understood Bill ;
    I wasn't suggesting going through the whole engine , just freshening it up like GM intended you to do .
    As long as it doesn't smoke when you're done , it'll be fine I am sure .
    I was taught to run the worn out engine and drive it 'round a bit to test the hot oil pressure etc. before taking it all apart so I'd know how much to replace when I had the head off .
    It's always worked for me , I rarely bore the block .
    Piston Rings & bearing shells are cheap when they result in a good running engine that runs As-New , doesn't smoke nor leak and will outlast me .
  13. Bill Hanlon
    Morris Ranch TX
    The world is a shit sandwich, and I'm the bottom slice of bread.
    Finished up the valve job Saturday night with lots of help from my brother Tom and my friend Ken. Had a helluva time getting the intake manifold to seal to the head, but finally got it. Did a 5 mile break in run. All was well.
    Sunday afternoon I took the truck out on a longer run (10 miles) and brought the speed up as far as 65 MPH (calculated 2607 RPM). Temp was around 185 and oil pressure was 50 PSI. When I backed off, the trucked slowed normally through about 58 MPH and then started making racket sort of like a Jake Brake. Wouldn't idle (idle speed previously 425 RPM). Poor power. Very rough.
    Took the valve cover off last night and found this:
    That's #4 exhaust, staying partially open by itself. The rocker can get so far away because of this:
    Removed the head and took it back to the machine shop with manifolds attached. All the other valves were free. This one could not be removed with easy hits from a dead-blow hammer. Shop didn't know what happened, but they are standing behind their work. They'll order another exhaust valve from Egge.
  14. Bill Hanlon
    Morris Ranch TX
    Never mind about the pushrod. O'Reilley's can have one for me in the morning for $3.49.
  15. Bill Hanlon
    Morris Ranch TX
    Forgot to say "no evidence of valve-to-piston" collision.
  16. Bilbo
    Bilbo Member
    Magnolia, Texas
    Well Bill... I hope you get back up and running in short order. When you do, You, Ken and I need to get together with JW's54 from Cypress and meet someplace with all our trucks. I'll buy lunch :)
    For Ken, Thanks again for the steering wheel. I'm working on it...
  17. Bill Hanlon
    Morris Ranch TX
    Hard part will be talking Ken into getting his Garage Queen on the road.:D
  18. Bilbo
    Bilbo Member
    Magnolia, Texas
    Are you gonna' need to extend your flat bed in order to carry Ken's 50? ;)
  19. ccharr
    ROFLMAF Thanks Bill for that great laugh, that was funny.
  20. Kens 50 PU
    Great idea!
