why does a head leak oil
Discussion in '1947-1954' started by ccharr, Jun 6, 2013.
  1. Blueflame236
    Blueflame236 Member
    Norway
    So far so good.
    Thanks for the update Charles.That carb solution looks very good. I`ll hope the oil leakage does`nt give you to much issues.I am a bit curious what the problem is ? Maybe its only the cover gasket that needs changed ?
    Thanks for sharing Martinius.
  2. ccharr
    Martinius,
    The oil issue is a little more than the valve cover, it is the rear main that is leaking the leak at the block and head looks just like Joe had stated earlier. The engine builder told me he used the neoprene seal on the rear, I think he used a medium or higher pressure oil pump because of the hydraulic lifters which were used and that is what has cause the leaks it has. I have read elsewhere on the net that by putting in the higher pressure oil pumps it causes oil leaks later. Right now the truck is running really good it is a little rich but that will change tomorrow.
    Charles
  3. Guest5979
    Guest5979 Guest
    get her ready
    wipe her down and get her ready for brothers this sunday
  4. Blueflame236
    Blueflame236 Member
    Norway
    Engine block.
    Thanks for explaning this to me Charles! But do you really need to take the top of or will it be anough to change out the pump or tighten (torque) the top bolts ?
    Martinius.
  5. ccharr
    :D I have, just have to repaint the plywood in the bed and maybe new fence around the bed.
  6. vwnate1
    Oil Pressure & Leaks
    I'm sure you can reduce the overall oil pressure by tweaking the pressure relief valve's spring , no ? .
    To lean it out a bit , just lower the float a tiny bit ~ works like a charm .
    I hope to make the Brother's Show , I need to empty out the bed , remove the ratty plywood covering the oak and wash it .
    I'm choking to death on the oil fumes so I'll have to drive with all the windows & vent wings open .
    If I can , I hope to park with the C/10 club ~ those are really nice guys .
  7. ccharr
    We will be looking for ya there.
    Was wondering if I should put keep the white spoke rims on or put the aluminum rims on for this show?
  8. vwnate1
    Wheels & Cactus
    This can only be decided by you Charles , you know what I'd slap on your rig ;)
    I think showing up with those cactus would be a big hit .
  9. Blueflame236
    Blueflame236 Member
    Norway
    Rims
    Charles
    I love those white rims of yourse and they fit well dont they , they remind me of the old fashion chevy 1 and 2 ton truck rims .
    Martinius.
  10. ccharr
    Martinius,
    I kept the white rims on also bought another rim and tire for the other side.
    Also because of the fiasco of the oil lines busting with oil being everywhere through the clean up I have found so far all the leaks.
    The side cover has a pin hole in it also it was loose and letting oil out at the very back where it is hard to see anything. Me having to power wash everything let me see a trail of oil I never had seen before. The pin hole has super glue in it for right now will get it tig welded later on.
    Charles
