Hello, I'm looking for a wiring diagram for a Chevy 1985 C10, because i have a problem with the headlghts. The lights are dim and won't light the normal way. thanks schleaper@hotmail.com
We, Chevy Duty do offer the wiring diagram for your truck, the part # is 52-993N, the current price is $ 7.95 and it is also in stock. Hope this helps.... Jesse Hazell Chevy Duty Tech.
i have same truck i had similar problem i replaced the ends of wire that plug into the light itself try that if not get the diagram and go fom there
Like Towman said, it may be the plugs that plug onto the back of the headlights. Try wiggling those around and see if that makes a difference, if so its not getting a good connection. In that case replace the ends, or attempt to clean and fix the plugs. This same thing happens with my dads 73 chevy, and my 79 chevy. Good Luck, - Shane
