53 chev truck V8 swap
I'm doing the same swap as you right now. I used the tubular crossmembers from Classic Chevy. The steering box has to be moved outward by 1 1/4-1 1/2 inches. Make a plate, or angle, to weld, or bolt on top of frame to move it outward by this much, keeping the new st. box mounting surface flat w the old surface. Also in an article in an old magazine I have from 1955, doing this same swap, they also moved the box, and had a machine shop mill the flange of the drivers exhaust manifold down by about 1/2", and they didnt have to move steering so far. I'm using block hugger headers, and had to put small ding where adjustment nut is on side of box. You can also move the engine slightly to the left w/o any problems. The steering arm has to be heated, and bent back toward the frame so the drag link is parallel w the frame.
Another alternaive is as a neighbor of mine did with his 53, cut off entire frame under cab, and graft on a Camaro, or Nova subframe, that has P.S, Disc brakes, and V8 mounts. Gtown Larry
