twhite
I am in the process of repairing the cab for my 53 1-ton. Actually it's more like rebuilding, because there is not much left below the lower hinges. I have repaired the rear lower corners, and they look really nice. But now I am starting on the floor and wheel wells, and I am worried that I am going to screw something up.
The problem is that the rust damage is so severe that I don't have much of anything to line up my repair panels with. I am having to replace the floor board, toe board, lower hinge pillars, inner and outer cowl panels, the cowl, and part of the sill on both sides. I haven't done any cutting to remove bad parts yet, I need to figure out how to keep things aligned before I rip out the old. And the cab sags so badly now from rust damage that I can't be sure onything on it would make a good base line for alignment.
Anyone have any ideas on this? Experience, suggestions? This is actually a 49 5 window that I am using to replace the original cab, which is also really bad, although I still have it sitting outside the shop. Any help would be greatly appreciated.
twhite
twhite
