Bill Hanlon
'52 GMC 150, 3/4 ton, 125" wheelbase, same as Chevy truck as far as this seal goes I think.
I need to replace the seal that keeps transmission gear lube from leaking out the back end of the enclosed portion of the "torque tube". These 3/4 ton trucks have the ball type cover over the U joint immediately behind the transmission and about 2 feet of "torque tube". Inside the rear of the tube is a seal that I need, a snap ring on the driveshaft, a sealed bearing and a snap ring to hold the bearing into the shaft. A splined U joint yoke bolts to the end of the enclosed driveshaft and connects to the rear, exposed, driveshaft and on to the rear end.
The seal is designed to run on a 1.5" OD shaft. I don't know the ID of the torque tube where the seal resides. GM part number is 3689176.
Anyone know where to get this seal?
