Bobby 57
Willy, Heres the pictures i told you about.The first photo shows the toyota gear box coming thrugh the origianal sector shaft hole of the frame rail. I had to take a dye grinder to sector shaft hole to add a little extra clearance. Note the 2 bolts on the side of the frame rail and the 2 bolts on the bottom of the frame rail, These hold the bracket that the gearbox mounts to.
The second photo shows the bracket. The gearbox was bolted to bracket first ,then set on the frame rail and clamped in place. One of the origianal bolt holes was used and i had drill a new and tap threads into the bracket on the rail. Then i drilled the two holes on the bottom of the rail and through bolted through the bracket and the frame rail per CPP's instructions.
The third photo shows the U-joint attaching the gearbox to the flaming river steering column. Note, i put a cooler for the power steering since the gearbox was close to the headers this did help to keep fluid temps down.
The fourth photo shows the column mount and floor board.
I hope these help.Give me a call if you have any questions and good luck.
Bobby
Bobby
