ssexton1
I have a 1954 3100 truck with Hydramatic transmission.
What part is needed to install the cable to the transmission?
Is there just a 1" or so diameter hole in the tail housing now or does it have a threaded "plug" in that hole? The hole or plug is on the left side just to the rear of where the tail housing bolts onto the main case. If the plug is there then all that is needed is a longer speedometer cable that what went on the 3sp trans. Picture shows a 54 tranny with the plug in place. Inside the plug is what is called the "driven" speedometer gear and on the transmission output shaft is the "drive" gear. If the Hydramatic trucks didn't have a 3.90 rear gear like the other trucks you will have to find the correct set of drive and driven gears but the car gears are the same size and design so it's easy to do. Sorry I don't know how to draw a circle around the plug like smart people do.
Sandy,
Would like to see your finished truck. Along about April, if gas is still down, my wife and I are going to drive the old 37 Buick to northwest Iowa near the Minnesota border. We usually go through KC on the by-pass that hits 29 near the airport but also can use 35 or 71. Anything near your neighborhood? The 37 Buick is kinda like it's owner, the exact same age, covering getting thin on top, and a little slow.
