If you end up not liking it I'll buy it from you. Mine broke the needle pointer shaft years ago and after using it for so long, feeler gauges suck. The P&G gives a reading that is dead accurate no matter how big an eyebrow is worn in the rocker arm from the top of the valve stem or how bad the rocker arms and shaft are worn. Even measures the thickness of the oil film layer. Also miss my P&G Combustion Gas Detector. It fit in place of the radiator cap and had a cylinder with green fluid in it. If it turned yellow there was a crack or bad gasket seal. You could isolate which cylinder by pulling plug wires and when the fluid stayed green, you'd found it. Especially handy on 235's since the crack is usually in the vertical wall of the combustion chamber and sometimes isn't as distinct with the magnaflux powder as ones on the face. When you knew which one was leaking you could give it close inspection to start with. I can't give you a step by step set up since it's been so long but I know it would come back to me with a little tinkering. Hot Rod magazine would have an archive article on it if their archives go back to the late 60's or early 70's, that's when I bought mine after reading about it's features. It is good for private use or on a performance engine but way to slow of set up time for repair shop use.
