Okay Jeff ;
Without looking inside of it I can tell you most common whine noise is caused by wear of the cluster shaft, it needs to be shimmed and over time as it wears it moves back a little bit so the gears don't mesh properly .
They make that whining sound because they're helical cut .
Chev's of the 40's in Washington state used to sell the synchro rings, bearings and gaskets along with the all important cluster gear shims .
New gears are out there, beware of "REPUBLIC" brand gears, they're apparently made of margarine .
If Joe can't help you, beware of any rebuilder as they usually only change the bearings and gaskets and call it a day then claim (lie) that it's "all new inside !" when the noises are still audible .
These never did have stellar synchronizing, I usually find the clutch or more often the pilot bushig in the end of the crankshaft is worn out or dry so it drags on ranny's input shaft .
If so this *must* be fixed before you waste a dime on tranny repairs .
The simply test is easy : get your truck all warmed up and park it, set the park brake firmly and depress the clutch, then select first gear~ a slight noise as it goes in is normal .
Keep the clutch pedal to the floor and shift from first gear into reverse
Did it crunch ? .
If it did, there's a clutch problem that needs fixing RIGHT NOW FIRST THING .
If not, you're one of the lucky .05%, go buy a Lotto ticket .
Depending on your skills you may well be able to over haul the tranny your own self .
Have you yet removed the side fill plug and stuck in your little finger to see how far below the edge of the filler hole the oil is ? .
These things weep, seep and leak oil as a matter of course, don't think you can ever stop needing to keep a weather eye on the gear oil level in the tranny .
Check the rear end too, if a gush of oil comes out when you remove the fill plug on the back of the differential the 'Oakie Bushing' is worn out and allowing oil to transfer from the tranny to the rear end .
Another fiddly but doable at home fix, takes some effort and a rental tool .
Keep us posted and do the simple test things first .
If you can put your little finger in the tranny's filler hole up to the knuckle before you feel oil, the oil is low and you MUST CHANGE IT not just top it up .
