As usual, I am confused. I thought the tough one was the cab windlace. The term windlace seems to be confusing enough. Sometimes it is just called what it is... weatherstripping and other times it is called a "seal".
I thought the door "windlace" was just glued on with the 3M adhesive then held in place at the bottom by a SS retainer strip.
Greg
Greg,
I assumed the "weatherstripping" was the one on the door glued on, and the "Windlace" was the one in the channel around the door on the cab side. I very well could be wrong.
-casey
I like the stuffing in from the side way even though it's tricky where the side of the dash is real close. For anything that lubing makes easier we use the original formula Go-Jo. It's slippery as snot and seems to last longer than soap plus it cleans up 100% with plain water. It is the cats meow for pushing a spark plug wire through a right angle boot.
