I am struggling with the connection of a cannister oil filter on my '51-3100. As usual, the Factory Assembly Manual is not much help. Section 0 - Sheet 6.00 shows two oil ports, but there are actually three [See 1st photo]. The first photo shows two ports with a bypass tube at each end. The third is closed with a red rubber plug.
The second photo shows the tee & street elbow fitting in the port that was plugged and the top hose from the cannister with the oil pressure line sitting on the frame. If I install the oil pressure line to the tee where does the bottom hose of the oil filter go?
If I take out one of the bypass connector and install the bottom hose there, that leaves an open port. It also makes the bottom hose touch the exhaust pipe [which cannot be good].
Help!
Greg
