Gas Tank Relocation?
6Kustom: with all the posts on here about the dangers of saddle tanks for side impacts, are you saying that "modern" day trucks like the Titan still comes with saddle tanks?
Yes, he is. BUT, those newer tanks are inside the frame rails closer to the center of the vehicle where studies have show is the safest location for fuel tanks in a collision,,, from any direction.
dv
ahhhhh... thanks dvalentine, I guess that would make them kind of reverse saddle lol....too bad I have a set of control arms there ;-) would be nice to put the tank there. I have thought about custom making a flat pancake tank that would fit about the driveshaft but that would require a driveshaft loop etc etc.
i havnt measured, but from being familiar with the chevys and the nissans my eyeball says it would be a close fit and should work. the tanks are a little narrower these days on some of the trucks due to haveing to clear transfer cases and drivelines, and Dvalintine is correct on the new tanks being inside the frame, another smart thing on new trucks is they come with boxed in frames.
i remember when i was a kid my dad had a brand new 77 chevy 3/4 ton 4x4 with the 454 with duel side tanks. Chevy's socalled recall on those consisted of turning your truck back in thus loosing the money you had already been paying into it, or they payed you back a small amount of $ and realesed them from liability. what a deal. :rolleyes:
years later a lady plowed into the side of dads truck, didnt blow up!! insurance fixed the body and back on the road it went.
Here are a few approaches we use to relocate fillers. First pictures are of a hinged board set up. The kit is very pricey so we use two 80's to 90's Cougar or T-Bird fuel door hinges along with the electric release and a screen door spring for a total cost of about twenty bucks. The next is a 66 with a blazer tank and the filler on the inside of the bed side. You can see the tank just behind the wheel in the left side shot and it is higher than the bottom of the fender.
Here's one more set up that makes an outside filler very unobtrusive. It is a "pop-up" cap that the motorcycle guys use. The kit is not pricey and if the chrome is sandblasted, primed, and painted body color it's not at all knobby looking like the factory cap.
Just Surffing around
I been reading different post here, this is my fill hole location, parts and tank from a CJ 7.
Stock Market
Will be buying stock in white vinegar later this week, the two extra gallons of fuel will be great to have and the breaded fuel hose I also used.
Never Die
We all resurrect these old iron trucks, dang! a post ant nothing, :D If I keep welding and burning stuff I will be a fabricator some day.
Fuel locations are all unique, I was thinking of enlarging the bed picket to hide everything. I could not handle all that fabrication.
I do believe my 1959 body is still stock except the fuel hole being filled.
.... I could not handle all that fabrication.
Sure you can handle it.... you've already proven you can: :)
First sanding and primer. I did used some of that red steel auto body putty. Need to work on the low and high points.
