Is it Worth rebuilding if not original engine on truck
Neto84
May 20, 2019
35
3
Age
42
Well I just found out I don’t have the original engine on my 54 Chevy 3100 series looks like I have a 58-62 engine 235 now is it worth rebuilding it I wanted to stay all original
The 54 engine is the least durable and desirable of the 235 full pressure engines. The head and lubricating system was by far better on the 58-62. Originality means zero to me so you may want to put this advice in the round file.
Considering that many can't tell the difference between a 216 and 235 (visually), and most probably can't differentiate between a Chevy motor and F**d motor, I'd say continue on with your efforts, and enjoy the truck. Back when these trucks were in service, they were TOOLS... like a circular saw. When they needed a new blade (engine), if the rest of the saw (truck) was in good shape, that's what happened.
Build it. DRIVE it. Enjoy it.
Where are you located?
Complete in great shape replacement 235 engines are available just have to hunt a little
A friend just got rid of one for a v8 swap
Any pics of you truck ?
Again welcome
ROBERT
Im in San Bernardino ca this the 54 3100
What is he going to do with the 235 engine did he ever rebuilt it
WELCOME NETO ! .
A nice looking rig you have there, unless you plan to restore it and make it a show truck you really don't want the original one year only 1954 engine .
The '57 ~ '64 235's are vastly better and pretty much everywhere cheap or FREE ~ just keep asking everyone yo see with a ,1963 Chevrolet of any typ, what they did with the old 235, 90 + % of the time it's just sitting, they thought they'd get BIG BUCK$ for it then reality set in and five years later it's still cluttering up the garage....
Don't pay more than $25 for one that's stuck ~ there are too many good running 235's yanked out for a chrome plated V-ate to ever pay much for one .
By the way ~
Unless it knocks or has a rod through the block it's a simple hing to overhaul the 235 engine in situ and cheaper too ~ these were designed to be FARM TRUCKS, easily and cheaply repaired in the barn or back yard...
? What's wrong with the engine it has now ? .
I just got the truck have been going thru the engine at first it started up and when come to a stop it shuts off oil was super black smush I decided to drop the oil pan and do a complete inspection of what was under their. Cleaned it all up it no cracks just black nasty oil.Rebuild the carburetor and a new fuel pump. After all that work I gave it a try to see if it started yes it did and it sounded better that what I first heard it running.
Hello Vwnate1
I don’t plan to make it a show truck anytime soon I want to get it going and drive cruise on a weekend
I removed the spark plug this is what I found black all around it and oil on the plug
O.K., that's a slightly sooty spark plug .
Before you do much else, go look up my older post on tuning the 216/235/261 engines and follow it exactly ~ no skipping steps or "the valves are fine" crap because they AREN'T .
There's a specific order to how the engines are tuned and once you learn it your truck will run better than anyone else's and you'll be able to amaze your friends and make money tuning up their old poorly running i6 Chevys & GMC's....
THE CARBY IS THE VERY LAST THING YOU SHOULD TOUCH ! .
Don’t forget to change oil with just 30 wt oil
Just 30 wt oil
On the research I found said to use 10w-30 oil
I’m going to do another oil change soon want to try to wash out all the black oil that was in their before
Ok thanks for all that info
