Lakeroadster
01-27-2012 New Header Gaskets
The ole orange crate has a slight header gasket leak so I decided to replace the exhaust header gaskets. For the engine to header gaskets I used stock manifold gaskets. They are metallic on one side and paper on the other. The paper side goes against the head, foil side against the header. Since the '65 has stock oval port 1970 heads using stock manifold gaskets just makes sense. The good folks at Chevy spent a lot of money designing these, so I'll take advantage of their hard work and ingenuity.
Here's the gasket set P/N's I ended up using:
Gaskets installed:
And to torque the back two header bolts on the right side this works pretty slick:
Gaskets installed:
