Rebuilding the 54
Discussion in '1947-1954' started by Climberdad, Oct 18, 2009.
  1. Climberdad
    Climberdad Member
    Argyle, TX
    Patricks has some .080 pistons and rings. The rod and main journals can go up to .035.
    It all depends on how badly the surfaces are scored.
    Cheers!
    Engine Overhaul
    Don't be in any hurry to turn that crank ! . if the journals are O.K., just slip in new bearing shells and call it a day .
    The cylinders , how much taper does it have ? . you're allowed up to .016" or so so cutting the ridge a bit then smoothing it flush with a ball hone might be a way to go , finish up by using some Chrome rings bedded in my way and you won't have excessive oil consumption .
    Due to casting shift , boring past .060" is unwise .
    Liners are available but , I've not found a competent Machinist to install them correctly in years ~ what they all do is : press in the new liners then make fast cuts instead of the time consuming slow cuts so not only do you wind up with brandy new .020" bores but they're slightly egg shaped too .
  3. Climberdad
    Climberdad Member
    Argyle, TX
    So far it's been a productive weekend. The cleaning and painting of parts takes a long time... I decided to take your collective advice and went with Grey for the engine color. I'm glad I did. We pulled the front springs to get them cleaned up. I'm replacing bushings and seals while I'm at it. The rear spring pin bushing was more the shape of an egg than a circle... Thankfully the pin had not worn completely through the bushing to the spring.
  4. Climberdad
    Climberdad Member
    Argyle, TX
    I've got the engine compartment pretty well cleaned up. Next I need to do some serious wiring cleanup. I found some green paint that was close... Once the hood is on it will be hard to tell. The whole truck is going to be painted - but that is another project;) I think I may need a new fan:eek: I am lucky that i did not have a blade fly through the hood! Anyone have one they want to part with? I never did like the white accents in the grill - so now they are gone.
  5. vwnate1
    Disaster Averted !
    You're wise to go with the gray , once you've re-painted all the engine accessories properly gloss black & added rockerbox decals , it looks really nice and correct too, not goofy like the Chevrolet orange things do .
    That fan was a lucky catch ! good thing you saw it before it punched the hood :eek:
    Farm fix back in the day was to wire brush off the rust & old paint , zap it real good with the buzzbox and slap it back on for another 50 years of hard service.... :rolleyes:
  6. Climberdad
    Climberdad Member
    Argyle, TX
    Funny Nate - I was thinking the same thing. I could not decide it there was a balance issue. I was able to find a NOS fan for $30 so I just decided to be safe. I guess I can weld the old one and have a backup...
    I picked up the clutch kit and water pump at the local ORiellys today. Waiting on the little intake manifold alignment rings to mock everything up. Hopefully it will be back together intime for this year's family Christmas card:rolleyes:
  7. vwnate1
    No !
    Just snap the cracked blade off and hang it on your garage wall and when the -one- guy notices it , lie through your teeth , make up an exciting story ya know....
  8. Climberdad
    Climberdad Member
    Argyle, TX
    LOL! I like that idea - it will go along with the bits I kept as momentos from my rock crawler...;)
  9. Climberdad
    Climberdad Member
    Argyle, TX
    Hello all,
    I looked back and it's been way too long since I posted... Lot's of time spent on other projects.
    Engine is done. Runs like a champ!
    Now for paint. I know the purists will not approve - but I just could not keep the stock green... Firewall has not yet been painted...
    Working on the interior as well...
  10. ccharr
    That is a great color, and your progress is good also. Keep the progess photos coming, Thanks.
  11. Kens 50 PU
    "A Choice of 12 Attractive Colors At No Extra Cost"
    Just like the Sales Brouchure said...
    I like the color too! I noticed 2 air cleaners! We need info and pics of the engine mods too!
    That's a definite "head turner"!
    Ken
  12. Climberdad
    Climberdad Member
    Argyle, TX
    Engine is "Period Correct". Original 235 - bored 60 over (clean up). Slightly shaved head. Mild cam. Dual Holly/Webber 2 barrel carbs on an Offenhauser intake. Cast iron split header. Electronic ignition. Stock 3 on the tree. Runs like a scalded cat... Will get some pics of the engine - got lazy during the end of that phase...
  13. spika
    spika Member
    Central Montana
    Wow, that's danged near the color of my Studester...I love it!!! That's gonna be beautiful. Fine work!
  14. herman quail
    herman quail Member
    Black mtn, NC
    I also like the color.I plan on doing a dark blue and your color gets my juices flowing.
    Could you tell me the color that you used.
    Steve
  15. Zig
    Dat's B-E-A-U-T-I-F-U-L!!!
    I love the color, Bruce! The engine looks mighty tough too!
    So are you doing the paint, or did someone else paint it for you?
    Thanks for the update! (Wish I could do the same...)
  16. Climberdad
    Climberdad Member
    Argyle, TX
    Thanks all!
    Color code info is attached. Jorge Diaz of Diaz Custom Classics in Denton, TX is doing the Paint/Body work.
    The interior was painted a darkish grey. The seat is being re-done in a black and grey suede. Headliner and door panels will match.
    Will post somemore photos next week.
  17. herman quail
    herman quail Member
    Black mtn, NC
    thanks for that info.
    will go to the local paint shop next week.
    steve
  18. 3/4 gmc 1952
    3/4 gmc 1952 Member
    Claremont, NH
    I also LOVE that color. I am planning blue and grey interior as well but I think I am going with Toyota Speedway Blue. I keep seeing those little blue trucks around town and the color really jumps out at you. That is a ways off however. Much work still to be done. Nice job and keep those pictures coming, they are like the carrot on the end of a stick for me!
  19. Climberdad
    Climberdad Member
    Argyle, TX
    Went by the upholstery shop and the headliner & door panels are done:) Seat will be done and installed this Saturday:)
    Went by the paint shop and everything is painted:) He has started the buffing process and tells mr I can have the truck back Saturday:D
    Lot's of pictures this weekend!
  20. Kens 50 PU
    Looking forward to seeing the pics! What I've seen so far have been very nice!
