We are removing the drip rails from a 65 short stepside since the only thing they seem to be good for is causing rust holes in the top. Trimmed off with a sawsall and tig welded all the way around the top which is a two day ordeal. Does anyone have a better/quicker way? I made a strip with a slight "V" in it that would overlap the roof and the top of the cab and was considering panel bonding it. No heat involved so warping would not be a factor but we would have to blend it in with filler instead of the lead being used with the welded joint. I have no idea what the vibration factor is on one of these tops but do know lead will soak up flexing and vibration almost forever but if this is not a factor the other way sure would be easier. Thank you; Evan
