Skeeter's 50. Questions and Build
Discussion in '1947-1954' started by SkeeterBilt, Aug 10, 2012.
  1. SkeeterBilt
    SkeeterBilt Member
    Sierra Vista, AZ
    motor work scares me, so dad helps me. so does wiring. but the wiring on these trucks seems easy. once i get the truck goin and have tags and such ill buy the wiring harness from out host and swap it to 12volt.
  2. ol' chebby
    Wiring is nothing to be scared of. Check out my tech.s
  3. SkeeterBilt
    SkeeterBilt Member
    Sierra Vista, AZ
    ol'chebby, your techs are awesome and make everything easier. on here and the hamb. gonna be doin the 88-98 bench seat mod, dont know if you wrote it up or chubby but.... yea it was chubs i think
  4. SkeeterBilt
    SkeeterBilt Member
    Sierra Vista, AZ
  5. 2OR4Wheels
    2OR4Wheels Member
    Sierra Vista, AZ
  6. 2OR4Wheels
    2OR4Wheels Member
    Sierra Vista, AZ
    BTW, I was browsing Google Images the other day to find some paint ideas, and I ran across another picture of "your girl". Picture was on some Brazilian rat rod blog. But I dont think you need to be able to read the language to appreciate the link. :D
    http://ratrodbrasil.blogspot.com/2012/09/rat-rod-girls.html
  7. SkeeterBilt
    SkeeterBilt Member
    Sierra Vista, AZ
    i know, well he went to look at a older c10 the other day. i have noooo idea why but he did say "its got a stock 4 link it the back, we could bag it easily" i think my dad has turned a corner.
    o0o0oohhh weeeeeeeeeee
  8. SkeeterBilt
    SkeeterBilt Member
    Sierra Vista, AZ
    well after 2 months inside to replace the cam and workin on it 4 days a week with a couple set backs, the truck was pulled outside. guess i had a good day. put the 2nd oil pan gasket on last week (knock on wood) no oil leaks. secret was to RGB the front and rear of the gasket on. let it dry and get the motor mount out of the way.
    used chubby's write up for the 88-98 chevy bench seat install. i did it a lil differnt but it works well and im diggin it. no more sittin on a bucket
    http://www.jalopyjournal.com/forum/showthread.php?p=8240340#post8240340
    also got my visor off ebay on the truck. its a re-pop and needs some tweekin to make it fit and look right. next i guess is to put the front back together and re-wire to 12v. can i use the floor starter to start the truck when its 12v or should i use a solenoid to a key or push start button?
  9. ccharr
    The change over does nothing to the foot starter.
  10. SkeeterBilt
    SkeeterBilt Member
    Sierra Vista, AZ
    yea i know that. but is it easier/better to have not use the foot starter?
  11. SkeeterBilt
    SkeeterBilt Member
    Sierra Vista, AZ
  12. ol' chebby
    That wire kit looks to rewire the truck, but still use the 2 fuse stock block. If yo are going to rewire the truck, I would use a complete wiring kit with a modern fuse block. I have used several EZWire kits with great success. If your wiring is in decent shape...(most are not) and you are just adding an alternator, you can use the generator wire to the alternator ( 1 wire style) and move the generator wire to the Batt. terminal on the regulator, then do away with the field wire. With a non 1 wire alt., you would need to add an exciter wire to the alternator from a switched source.
  13. vwnate1
    Basic Up Grades
    The pedal starter works fine and helps prevent random kiddies from stealing your truck . I'd retain it as it'll work terrific with 12 volts through the old 6 volt starter .
    If you use a '49 wiring loom and fuse box , you'll have all the fuses you'll ever need . the stock '49 loom is about $150 .
    Reducing the fuses to two in '51 (?) was a bad cost cutting move my GM IMO .
  14. 2OR4Wheels
    2OR4Wheels Member
    Sierra Vista, AZ
    Its looking good! I like that seat in there, spaces for seat belts. Did you pick that up from the yard (M&R)?
  15. SkeeterBilt
    SkeeterBilt Member
    Sierra Vista, AZ
    thanks chebby. my wiring in the truck isnt lookin good. the clothe is fallin off and isnt lookin go0d at all. the truck has a bit of a hard time startin with the 6volt and generator.
    yea i did. walked around till i found one that wasnt ripped apart. the one i got isnt perfect but it isnt ripped apart. ill put a cover or mexican blackets on it.
    i like your idea vwnate
  16. ol' chebby
    Then do a complete rewire.....it isn't worth a fire or being stranded at the most in opportune time.
  17. SkeeterBilt
    SkeeterBilt Member
    Sierra Vista, AZ
    yepppp. thats why im lookin into the 12v conversion. my middle name is murphy. and murphys law is a biotch. skeeter murphy bilt
    im readin your write-up ol'chebby on how to wire up a truck
  18. ol' chebby
    It really isn't difficult. Just take it one circut at a time and plan out your install.
  19. SkeeterBilt
    SkeeterBilt Member
    Sierra Vista, AZ
    yeaaaa..... im a lil worried. but i think i can do it. but your write up is awesome
  20. ol' chebby
    Hit me up if you have any questions.
