Bill Hanlon
The rest of you guys need to jump in with troubleshooting ideas. I'm running low.
Zig: You still owe me a picture of the distributor and plug wires all hooked up.
and the thought that he's a bit off.
Either will work
I told Bill over and over that the wires were fine!
Wellll.... It turns out my dyslexia got the better of me when I wrote the firing order down, It seems I had the #4 and #2 switched.
YaBut ... This occurred (or at least was found) when the cap was also on 180 degrees out so fixing the two crossed wires had no effect on the the engine (didn't) run at the time.
Reference
Like someone else said above. It does t matter where 1 ends up on distributor, as long as your rotor is under 1 on compression stroke Some like 6 o'clock. Some like 12
Only restriction is grease cup
Dam Zig, Tubby's is set up like yours with #1 away from the engine block. Maybe MINE is backwards!!!
No matter where #1 is if the timing light (or static timing done with the engine off) hits the ball and the order going clockwise is 153624.
